Audiolab/Lakewest MDAC 2: ovvero DSD - usb 32bit 768khz - DUAL SABRE 9018
+10
robertopisa
bartman
turo91
BluesBrother
Doc_Zero
Edmond Dantes
luigigi
Alessio Zenga
Solomon
14 partecipanti
Pagina 1 di 3
Pagina 1 di 3 • 1, 2, 3
Notizie interessante ed ufficiali riguardo il progetto di sviluppo di una nuova versione dell'MDAC.
Il sogno diverrà realtà nel 2014. Con fasi progettuali a step e prenotazioni aperte sin da oggi
Queste le caratteristiche da vero fuoriclasse...
Qui il sito di riferimento
http://mdac2.lakewestaudio.com/
la fonte di riferimento
http://www.pinkfishmedia.net/forum/showthread.php?t=144127&page=13
L'idea mi solletica non poco i neuroni binari con filtro antialiasing...
- Dual ES9018 Sabre32 DACs, one dedicated chip per channel for true dual mono operation.
Brand new discrete Class A analog stage design.
Redesigned on-board power supply circuitry guaranteeing optimal performance using the stock AC adaptor.
High Speed USB 2.0 controller for asynchronous USB Audio Class 2.0 with 32 bit resolution and up to 768 kHz sampling rates. Driverless operation under MacOS X and Linux as well as Windows with UAC 1.0 fallback (up to 96 kHz). Optional open-source ASIO driver for Windows to support UAC 2.0 capabilities.
DSD 64Fs supported via USB as well as S/PDIF with DSD 128Fs and higher available via USB (DoD standard).
FPGA on board, opening the doors to limitless customization and further improvements delivered via software updates. Ability to bypass all internal processing in the Sabre32 and replace it with custom LakeWest developments down to the noise shaper.
RAM buffer for memory play without ASRC for S/PDIF sources. Asynchronous USB and transport ClockLock interface ASRC free playback or optionally S/PDIF playback with ASRC without memory buffer induced latencies.
Passive AV bypass unbalanced inputs allowing coexistence of analog preamplifier / surround processor with the DAC’s own digital preamplifier.
4W XLR Female on the rear panel for balanced headphone connection.
Made in EU, each unit tested and qualified personally by JW
Numero di messaggi : 2237
Provincia : Palermo
Re: Audiolab/Lakewest MDAC 2: ovvero DSD - usb 32bit 768khz - DUAL SABRE 9018
È un progetto molto stimolante, l'idea di concentrare le forze, e i costi, sulla solo pcb da sostituire a quella attuale dell'MDAC riutilizzandone il "guscio" promette di offrire dei benefici in termini di qualità/prezzo del prodotto finale notevoli.
Per chi fosse interessato la Lakewest offrirà anche la possibilità di acquistare degli MDAC da usare come "donatori di organi" a prezzo ribassato (ca.£350) in quanto si tratterebbe di prodotti "di recupero".
Numero di messaggi : 1418
Provincia : Treviso
Impianto : A manovella
seguo affascinato ...Alessio Zenga ha scritto:È un progetto molto stimolante, l'idea di concentrare le forze, e i costi, sulla solo pcb da sostituire a quella attuale dell'MDAC riutilizzandone il "guscio" promette di offrire dei benefici in termini di qualità/prezzo del prodotto finale notevoli.
Numero di messaggi : 2734
Provincia : Lodi
Molto, molto interessante!!!!! Grazie mille, Boss!!!!!!!!!!!!!!!!!
Edmond Dantes- Affezionato
Numero di messaggi : 244
Impianto : Sistema alta efficienza multiamplificato, giradischi e lettori digitali vari.
finalmente qualcuno che pensa a farsi volere bene dai propri clienti
certo il fatto che di mdac usati, nonostante sia in circolazione da un paio d'anni, praticamente non se ne vedono mai lascia immaginare che chi l'ha preso ne sia stato molto siddisfatto. mi è sempre rimasto il tarlo di non averlo mai provato ma non lo comprerei mai nuovo adesso...inizia ad avere qualche specifica ormai un pò datata
Doc_Zero- Affezionato
- Data d'iscrizione : 02.07.13
Numero di messaggi : 232
Provincia : RM
Impianto : Norma Revo IPA-140
Oppo BDP-105D
Opera Quinta SE
Schiit Bifrost Multibit
Pioneer PL-630
Pro-Ject Phono Box RS
Secondo voi quanto potrebbe costare?
BluesBrother- Affezionato
- Data d'iscrizione : 19.09.10
Numero di messaggi : 131
Impianto : Auzentech Prelude X-Fi -> Adam Sub7 -> Focal CMS 50. Cavi Monster cable. Beyerdynamic DT770 Pro 80 ohm
Davvero interessante
Io punto sui 1.200 minimoBluesBrother ha scritto:Secondo voi quanto potrebbe costare?
turo91- Membro classe argento
Numero di messaggi : 4587
Provincia : Sbilanciato
Non credo ... visto la fascia di prezzo dovrebbero rimanere entro € 1000..turo91 ha scritto:Io punto sui 1.200 minimoBluesBrother ha scritto:Secondo voi quanto potrebbe costare?
Poi raccolgo le scommesse
Quindi dite più del M-DAC... mumble mumble... certo che se si può comprare la versione vecchia a 350 euro sarebbe un affare... bisognerebbe indagare...
Con due sabre 9018 che lavorano in mono?Stentor ha scritto:Non credo ... visto la fascia di prezzo dovrebbero rimanere entro € 1000..turo91 ha scritto:Io punto sui 1.200 minimo
Per ora qualsiasi cosa contenga un solo sabre costa minimo mille, quindi per me sotto i mille non ci sta
Poi dipende anche da cosa scelgono per l'alimentazione, se usano ancora l'ali da rasoio magari sotto i mille ci sta pure.
Il secondo sabre gli costerà 50 dollari in più ...e forse esagero .....turo91 ha scritto:Con due sabre 9018 che lavorano in mono?Stentor ha scritto:Non credo ... visto la fascia di prezzo dovrebbero rimanere entro € 1000..
Lo avesse fatto una azienda con vocazione hi end è un discorso ma l'Audiolab ha una vocazione budget e credo (o forse spero ) che rimanga in questo ambito
Un super affare ...ma la vedo duraBluesBrother ha scritto:Quindi dite più del M-DAC... mumble mumble... certo che se si può comprare la versione vecchia a 350 euro sarebbe un affare... bisognerebbe indagare...
bartman- Membro classe bronzo
Numero di messaggi : 1564
Impianto : Fuso!
Lo so, ma è un'attimo far salire il prezzo finale di 400 euro per la feature unicaStentor ha scritto:
pardon, in che senso la vedi dura?Stentor ha scritto:Un super affare ...ma la vedo duraBluesBrother ha scritto:Quindi dite più del M-DAC... mumble mumble... certo che se si può comprare la versione vecchia a 350 euro sarebbe un affare... bisognerebbe indagare...
Comunque temo avrà ragione Turo...
So che Sal alzerà gli occhi al cielo, ma pensate sia inutile sostituire l'ali da rasoio con dei trafo seri ? E' che non ho capito come sono i secondari (un capo in comune ? )turo91 ha scritto:
Provincia : Lodi
I prezzi previsti per la PCB dell’MDAC2 sono di circa £450/£500 (GBP) se ben ricordo, con due possibili opzioni di upgrade che utilizzano speciali resistenze Chrarcroft Bulk Foil (ma non vi sono ancora certezze al riguardo) che farebbero lievitare ulteriormente il prezzo rispettivamente di £50 o £350 (GBP). A questi costi va aggiunto il prezzo dell’MDAC che, potrebbe essere acquistato “di recupero” direttamente dalla Lakewest a ca. £350 (GBP).
Vale la pena precisare che questo MDAC2 non è offerto dalla Audiolab, bensì dalla Lakewest –l’azienda di John Westlake, progettista dell’MDAC - e dell’MDAC Audiolab usa solo il guscio, infatti è coperto da garanzia a vita Lakewest in quanto l’originale garanzia Audiolab ovviamente decacde non appena si apre il Dac.
Provincia : Treviso
ma insomma, ci vuoi dire come suona il tuo dopo le modifiche del guru ? sei reticenteAlessio Zenga ha scritto:I prezzi previsti per la PCB dell’MDAC2 sono di circa £450/£500 (GBP) se ben ricordo, con due possibili opzioni di upgrade che utilizzano speciali resistenze Chrarcroft Bulk Foil (ma non vi sono ancora certezze al riguardo) che farebbero lievitare ulteriormente il prezzo rispettivamente di £50 o £350 (GBP). A questi costi va aggiunto il prezzo dell’MDAC che, potrebbe essere acquistato “di recupero” direttamente dalla Lakewest a ca. £350 (GBP).
Provincia : Lodi
Opsss avevo capito fosse Audiolab ...Alessio Zenga ha scritto:I prezzi previsti per la PCB dell’MDAC2 sono di circa £450/£500 (GBP) se ben ricordo, con due possibili opzioni di upgrade che utilizzano speciali resistenze Chrarcroft Bulk Foil (ma non vi sono ancora certezze al riguardo) che farebbero lievitare ulteriormente il prezzo rispettivamente di £50 o £350 (GBP). A questi costi va aggiunto il prezzo dell’MDAC che, potrebbe essere acquistato “di recupero” direttamente dalla Lakewest a ca. £350 (GBP).
Ivano, hai una sindrome compulsiva da avatar ? ci fai venire il mal di testaStentor ha scritto:
Provincia : Lodi
luigigi ha scritto:Ivano, hai una sindrome compulsiva da avatar ? ci fai venire il mal di testaStentor ha scritto:
Il mio MDAC è tornato da Westlake per la modifica delle resistenze e qualche altro piccolo upgrade, quando mi arriva vi faccio sapere.luigigi ha scritto:ma insomma, ci vuoi dire come suona il tuo dopo le modifiche del guru ? sei reticenteAlessio Zenga ha scritto:I prezzi previsti per la PCB dell’MDAC2 sono di circa £450/£500 (GBP) se ben ricordo, con due possibili opzioni di upgrade che utilizzano speciali resistenze Chrarcroft Bulk Foil (ma non vi sono ancora certezze al riguardo) che farebbero lievitare ulteriormente il prezzo rispettivamente di £50 o £350 (GBP). A questi costi va aggiunto il prezzo dell’MDAC che, potrebbe essere acquistato “di recupero” direttamente dalla Lakewest a ca. £350 (GBP).
P.S.: se qualcun'altro avesse già beneficiato del servizio di upgrade dell'MDAC offerto da Westlake, sappia che può acquistare la PCB dell'MDAC2 "al costo", ossia ca. £125 (GBP).
Provincia : Treviso
In attesa che ritorni il tasto reply che non trovo più (e che mi ha fatto fare un casino in altro thread ), mi unisco all'interesse generale verso la prima unità MDAC upgradata del forum! Alessio, non vedo l'ora di sapere come suona, e che differenze hai percepito rispetto la versione liscia.
In effetti volendola vedere dal punto di vista pratico, avendo già un mdac, tentare di avere l'mdac 2 non dovrebbe essere eccessivamente costoso, specialmente se dovesse suonare veramente bene il dual mono DSD super sovereign.
Provincia : Palermo
Ma chi non ha un mdac deve comunque procurarselo? Oppure Westlake fornisce tutto lui chiavi in mano?
La cosa ganza è che mette un buffer per memory play invece che una ASRC dopo l'SPDIF, vedrete che i cavi SPDIF avranno meno effetto in questo modo.
Numero di messaggi : 1696
Provincia : Pisa
Impianto :- premi per vedere:
- pannelli T-class
- IKEA bass trap
- Metal bass trap
- Limp mass bass trap
- Soundwall
- CD: Marantz SA-11S2
- pannelli T-class
» SABRE D18 32Bit/500KHZ DAC use ESS9018(32BIT DAC)
» Audiolab MDAC
» Audiolab MDAC - a milano introvabile
» Dac con sabre 9018 e uscite bilanciate
» Audiolab Mdac - chi lo conosce ?
» Audiolab MDAC
Pagina 1 di 3
Oggi alle 11:54 Da fileo
