Hypex AS2.100 Digital
http://cgi.ebay.it/HYPEX-Aktivmodul-AS-2-100-Digital-/310225766927?cmd=ViewItem&pt=Lautsprecher_Selbstbau&hash=item483ae58a0f#ht_5276wt_984
Sul sito ufficiale ulteriori dettagli..:
http://www.hypex.nl/
The AS2.100 is a plate amp for use in powered speaker systems. Being an active speaker controller, the AS2.100 forms the basis of, for instance, a powerful active two-way monitor. In stereo mode one AS2.100 will power an active master / passive slave pair. The AS2.100 Digital is a AS2.100 including the optional digital add-on board.
Specifications
GENERAL FEATURES:
- Fully controlled by PC software (included)
- Cross-over settings fully customisable (real-time)
- UcD100OEM (2x) powered
- Stereo analogue input
- S/PDIF input and output
- Sampling rates up to 192kHz
- USB Audio
- Infrared remote control (optional)
- Automatic input scanning
- compact design
- Fully user customised filtering
- Button panel controlled
- Remote controlled
- Filtered sub out
- Link connection master / slave (only with two modules)
- Low signal to noise (-100dB)
APPLICATIONS:
When one module is used:
- Stereo passive filtered system
- Bridged mode for single subwoofer (max 140Watt @ 4 Ohms)
- Mono/mid 2-way setup (tweeter + sub)
When two modules are used:
- 2-way active filtered stereo system
- 2 channel system, both modules in bridge mode for more power
- 3-way active filtered in combination with an active subwoofer (filtered sub out on AS2.100)
All setups are possible with analogue and the digital audio inputs SPDIF and USB.
TECHNICAL DATA:
Supply voltage: 230Volt AC/50Hz +/-10%
Output power LS1: 100W @ 4Ohms
Output power LS2: 100W @ 4Ohms
MECHANICAL DATA:
Dimensions: 115mm x 200mm x 60mm (W x H x D)
Weight: 1.6Kg
bru.b- Membro classe bronzo
Numero di messaggi : 1390
Provincia : Torino (Ivrea)
Streamer - Rasp 3 + Digione
Aune S6 Pro
Re: Hypex AS2.100 Digital
Visto che è sostanzialmente passato sotto silenzio, riuppo questo topic per domandare se secondo voi si diesce a realizzare un ampli con questo modulo integrato.
Molto interessante, credo che il loro utilizzo principale sarebbe in un diffusore attivo di alta qualità, mi vengono in testa subito i grandi sistemi genelec o giù di lì.
Numero di messaggi : 10423
Provincia : Lupiae
» Hypex UcD180 volevo qualche notizia
» sezione di alimentazione TA3020 implementazione passo a passo
» Hypex ??
» hypex ucd 180 hg + hxr
» Hypex
» Hypex ??
» Hypex
Ieri alle 21:59 Da Forfaber
Ieri alle 14:01 Da valterneri
Ieri alle 7:51 Da saltonm73
Lun 6 Mag 2024 - 21:58 Da morgana90
» AKM VS ESS
» NAD 541i
» Lettore CD portatile
» Casse passive
» Casse passive
