» Ortofon 2m red 50,00 + s.s
Oggi alle 14:05 Da kalium
Oggi alle 13:48 Da Fabio Menozzi
Oggi alle 13:18 Da vinse
Oggi alle 12:27 Da Nadir81
Oggi alle 11:08 Da scontin
Oggi alle 10:52 Da Albert^ONE
Ieri alle 9:25 Da Rino88ex
» eredi delle kro craft (?)
» ampli a valvole
I nostri membri hanno inviato un totale di 812885 messaggi in 52810 argomenti
Fabio Menozzi
timo74
Silver Black (15531)
Biagio De Simone (10299)
fritznet (9513)
In totale ci sono 45 utenti in linea: 7 Registrati, 0 Nascosti e 38 Ospiti :: 1 Motore di ricerca
Annapdf, kalium, landrupp, Nadir81, Rino88ex, Sestante, sportyerre
DAC nuforce e akg272 hd
Messaggio  biiotechano il Ven 18 Feb 2011 - 15:10
Come da titolo vorrei fare questa accoppiata(teorica) akg k272 hd e il
NuForce uDAC-2:
Input
USB (USB 1.1, 2.0 compatible)
USB DAC: USB 1.1, 2.0 compatible. USB native bit rate: 32, 44.1, 48, and 96 kHz, 24-bit
Maximum sampling rate: 96kHz
Resolution: 24-bits
Output
Analog RCA Output = 2Vrms
Dynamic Range: 110dB
THD+N= -95 dB
S/N Ratio: 98dB
Digital Output: coaxial RCA 75-ohm
Headphone output jack
Power output: 80mW x 2 @ 16-Ohm
THD+N 0.05%
Headphone impedance 16-300 Ohm
Power
USB Bus Powered, 80 mA/5V
Maximum power consumption: 500mW
o il NuForce Icon:
Specifications
Input
RCA
3.5mm Stereo
Speaker Outputs (RJ45 connectors with 15 micron thick gold plating). NuForce RJ45 to banana plug speaker cables are provided with NuForce Icon.
Headphone Output
Maximum output @32 ohm Load: 31.25mW
THD (20Hz ~ 20KHz) : < 0.03%
Frequenc Response (20Hz ~ 20KHz) : < -1dB
Line Out (for Subwoofer) connection
USB DAC: USB 1.1, 2.0 compatible. USB native bit rate: 32-48kHz, 16-bit
Power = 12WX2. Peak power =15WX2
THD+N=0.05%, 1kHz, 2W @ 4 ohm load. THD+N=0.06%, 1kHz, 2W @ 8 ohm load.
Power Bandwidth : 26Hz ~ 50kHz, -1dB, 1W @ 4ohm load
SNR = 84 db at 7W @ 8ohm
Maximum sampling rate: 48kHz
Resolution: 16-bit
S/N Ratio: 98dB
Power Adapter - 12-14V, 25W, 100-240VAC worldwide voltages
Dimension: 6" x 4 1/2" x 1"
Weight: 1 lb. Shipping weight 5 lb.
Vorrei dei pareri generali sulla loro qualità musicale e molto importante se riuscirei a pilotare le cuffie in titolo. grazie a tutti.
biiotechano
Data d'iscrizione : 15.02.11
Numero di messaggi : 267
Occupazione/Hobby : Studente/Musica/Cinematografia
Impianto : Macbook--->780 Hfi
Re: DAC nuforce e akg272 hd
Messaggio  jankovic il Ven 18 Feb 2011 - 15:22
posseggo l'icon, personalmente l'uscita cuffia non la trovo granchè...capisco che è comodo soprattutto come impiantino minimalista da pc...considera che comunque il dac interno dell'icon ( non l'icon due ..non lo so...) non supporta i files ad alta definizione Smile . non conosco l'udac 2 ma se ne dice un gran bene
jankovic
Data d'iscrizione : 13.01.10
Numero di messaggi : 3673
Messaggio  biiotechano il Ven 18 Feb 2011 - 23:44
infatti del nuforce icon semplice anche dalle caratteristiche non sembra proprio un granchè anzi non supporata nemmeno cuffie ad alta impedenza e lo fanno pagare pure salato.
biiotechano
Messaggio  biiotechano il Ven 18 Feb 2011 - 23:54
@jankovic ha scritto:posseggo l'icon, personalmente l'uscita cuffia non la trovo granchè...capisco che è comodo soprattutto come impiantino minimalista da pc...considera che comunque il dac interno dell'icon ( non l'icon due ..non lo so...) non supporta i files ad alta definizione Smile . non conosco l'udac 2 ma se ne dice un gran bene
scusa visto che sono alle prime armi,come potrei risolvere il dilemma.io vorrei attaccare il tutto sia a delle buone cuffie che a un buon impianto casse 2.0. Per il momento mi basterebbe un buon suono in cuffia e accontentarmi del mio vecchio impianto casse. Quindi mi servirebbe un qualcosa di espandibile da poi collegare a due buone casse(penso meglio non amplificate). Dimmi se ho capito. O acquisto un DAC usb con uscita cuffie(non molto performante) o acqusto un DAC usb che poi collego a un amplificatore(giusto?)che magari avrà una buona uscita per le cufffie o per le casse.scusa sto giro infinito ma sono nuovo.
p.s. dimenticavo il DAC da collegare al macbook
biiotechano
Messaggio  Link70 il Sab 19 Feb 2011 - 12:25
Non ci arrivi a prendere l'Icon HDP?
Link70
Data d'iscrizione : 27.09.10
Numero di messaggi : 405
Messaggio  biiotechano il Sab 19 Feb 2011 - 12:31
@Link70 ha scritto:Non ci arrivi a prendere l'Icon HDP?
è ottimo ma troppo esoso(450 pesetas) vorrei mantenermi sulle 150 200 max.Dovrei specificare Studente universitario(futuro disoccupato) nel mio profilo
biiotechano
Messaggio  Link70 il Sab 19 Feb 2011 - 14:14
Allora perché non risparmi ancora di più ed inizi a divertirti con questo:
http://cgi.ebay.it/Topping-TP30-USB-DAC-Class-T-Headphone-Amplifier-TA2024-/290526676605?pt=LH_DefaultDomain_0&hash=item43a4bd467d#ht_9723wt_1243
se ne parla qui:
http://t-class.niceboard.org/t8744-topping-tp30-basato-su-ta2024c-con-dac-integrato?highlight=topping
Secondo me non va male e con i soldi che avanzi vai ad un bel concerto oppure li metti da parte come salvadanaio per i diffusori... Wink
Link70
Messaggio  jankovic il Sab 19 Feb 2011 - 14:28
perche' non un audiotrak prodigy hd? e' un ottima scheda audio, ha una buona uscita cuffia e "legge" i files a 24/96 kHz..oppure potresti rivolgerti al mondo pro vedi www.strumentimusicali.com e cercare una bella scheda audio con uscita cuffia...personalmente ho separato l'impianto stereo da quello per l'ascolto in cuffie...pero' onestamente ho l'udac2 tra i prossimi acquisti..nuforce imho e' un costruttore fantastico..ho avuto e venduto alcuni ampli, ma l'icon e' sempre li..e' un piccolo capolavoro, e il buon cadeddu conferma Smile
jankovic
Messaggio  biiotechano il Lun 21 Feb 2011 - 11:28
Sono indeciso fra l'icon nuforce udac-2 e il Topping TP30 USB DAC Class T. Non mi spiego però se l'Icon ce la farebbe a pilotare bene delle cuffie come le akg a 55 ohm di impedenza semplicemente attraverso presa usb. Purtroppo non posso provare il tutto.
biiotechano
Messaggio  biiotechano il Lun 21 Feb 2011 - 22:15
Allora vorrei una delucidazione, diciamo che un impianto classico per cuffie messo in serie è pc-->dac usb(e7)--->ampli cuffie(e9)--->cuffie
Io vorrei una cosa del genere , in grado di ascoltare con una buona qualità e soprattutto riuscire a pilotare delle akg 272 hd o una ATH-M50(una cuffia che mi dia suoni freddi e definiti,con bassi non troppo alti diciamo). Vorrei spendere max 350 euro in tutto(dac+amp+cuffie). Consigliatemi anche buone configurazioni fuori budget.
biiotechano
Messaggio  Link70 il Mar 22 Feb 2011 - 7:50
@biiotechano ha scritto:Allora vorrei una delucidazione, diciamo che un impianto classico per cuffie messo in serie è pc-->dac usb(e7)--->ampli cuffie(e9)--->cuffie
Per stare nel budget io prenderei il TP30 col 2024
e le Grado Prestige SR-125i
http://www.playstereo.com/product_info.php?cPath=6&products_id=1420
andando fuori budget prenderei l'icon HDP e a questo livello andrei in giro ad ascoltare un po' di cuffie per scegliere quella che preferisco.
volendo spendere ancora di più prenderei il Burson Audio HA-160D.
Link70
Messaggio  robertor il Mar 22 Feb 2011 - 8:09
una cuffia che mi dia suoni freddi......
una cuffia che ti dia il mal di testa immediatamente insomma.
Data d'iscrizione : 17.06.08
Numero di messaggi : 4049
InDiscreto Phono
Shure M75
Buffer B1
http://www.anitavillaetyek.hu
Messaggio  biiotechano il Mar 22 Feb 2011 - 23:52
Penso che non potrò spendere di più . Cmq tra un sistema icon udac2+ampli,Fubar III MKII,TC-7520SE Caiman,super pro dac(un must)+ ampli cosa sarebbe meglio? Ma queste akg proprio nessuno le consiglia,ormai è solo il marchio ad andare avanti?
biiotechano
Messaggio  biiotechano il Mer 23 Feb 2011 - 19:26
forse sono arrivato a una decisione per le cuffie...ho abbandonato l'idea delle akg...le grado. sono indeciso fra le sr125,le alessandro ms1 e le alessandro ms2. Per queste cuffie è necessaria una buona amplificazione o basterebbe un buon DAC con amplificatore integrato? grazie
biiotechano
