[MI] ICEpower 125ASX2 + DAC 192/24 ES9023 & USB XMOS ASINC I2S By Meral - 250Euro
Ottimo e ben suonante amplificatore con modulo B&O Ice power 125ASX2 125W con potenziometro ALPS, uno dei migliori. L'amplificatore oltre che ingresso RCA presenta ingresso USB Asincrona (192Khz/24b) con XMOS e collegamento I2S con DAC ES9023, alimentazione separata per DAC e USB tramite regolatori a basso rumore.
2 Ingressi RCA e USB
Ottimi connettori RCA come potete vedere dalla foto.
Contenitore il alluminio.
In vendita anche su altri siti.
Caratteristiche
ES9023 DAC Chip
● 0.1% Low Noise Thin Film Resistors at Signal Pass and Regulator Circuit
● Low ESR Tantalum Capacitor
● High Quality SMD Film Capacitor
● WIMA FKP2 Capacitor for Output Filter
● Ultra Low Noise Regulator Circuit
- Noise: 8nV√Hz @1KHz
- PSRR : 106dB
● Gold Plated PCB
● I2S Input(MCLK, DATA, LRCK, BCK, GND)
● Dynamic Range : 112dB
● Output Level : 2.0V RMS
● THD + NOISE : 0.002%
● Resolution/Sampling Rate : Up to 24bit/192KHz
● DC Offset : <4mV
XMOS 384kHz high-quality USB to I2S PCB with ultralow noise 6.5uV regulator
Feature:
6.5uVrms Ultralow noise linear power regulator (use of decade old LM317/1117 regulator is kidding for audiophile)
Solid ground plane (a must for high speed digital circuit)
FOX ultra low ppm oscillator and Murata capacitor sourced from Digikey USA (guarantee no fake product from China)
Gold plate USB connector (Molex, FCI, or other depends on stock)
No drivers needed for MAC OS version 10.6.4 and above
No drivers installation required for Linux with UAC2 compliant kernel
ASIO/KS/WASAPI/Direct Sound drivers for Windows XP to 8 (32 and 64 bit)
Caratteristiche
ES9023 DAC Chip
- PSRR : 106dB
● Gold Plated PCB
● DC Offset : <4mV
Feature:
meral964- Membro di riguardo
Numero di messaggi : 765
Impianto : In Firma.
» ICEpower 125ASX2
» FINALE B&I Icepower 125ASX2 e Pre TVC
» Finale Icepower 125asx2
» [TV] Amplificatore ICEpower 125ASX2 2 moduli - Euro 380 + SS
Oggi alle 1:33 Da giucam61
Ieri alle 21:22 Da valterneri
Ieri alle 21:20 Da beppe61
Ieri alle 13:25 Da salvo93
