Classe Z - Z-Forum? :)
+6
Giannast
kingbowser
wincenzo
10 partecipanti
mgiombi ha scritto:Non conoscevo la classe Z...
wincenzo ha scritto:Già sembra molto interessante chissà se ci sono amplificatori che sfruttano questa tecnologia?
Ho aperto questo nuovo thread...magari interessa...a me si!
Numero di messaggi : 3107
Provincia : Sinusoidale
Re: Classe Z - Z-Forum? :)
Altre informazioni sulla Classe Z (D) sono qui:Diodes Incorporated ha scritto:
Zetex and NAD Electronics unveil collaboration in the development of high-performance digital audio amplifiers
May 2007
NAD Electronics and Zetex Semiconductors announce the joint-development of high-performance digital amplifiers incorporating Zetex Class Z direct digital feedback amplifier (DDFA) technology, a unique performance-optimised digital amplifier architecture.
NAD is a brand known for delivering audio products with outstanding performance and value for money. The intelligent deployment of new technology is a cornerstone of the NAD philosophy, but the overriding principle is that “it must bring a performance advantage”. Of digital amplifier technology itself, NAD has set a high barrier for acceptance; The audio performance must match or exceed that of the best linear amplifiers to be considered. The only solution to pass this test is the Zetex DDFA technology.
Greg Stidsen, NAD�s Director of Product Development explained, “The high efficiency of Class D is well known and advantageous, but this alone does not qualify it for inclusion in a NAD product. With the Zetex technology we get the efficiency, but more importantly, the no-compromise audio performance our customers expect.”
The Zetex prime objective for DDFA products is to provide the semiconductor technology to enable it�s customers to manufacture products of the highest possible audio quality. Realizing the potential of the digital amplifier concept, where the whole amplifier process is performed in the digital domain, delivers fundamental advantages over conventional approaches. Abolishing digital to analogue conversions and implementing control functions in the digital domain brings performance to a new level.
“Zetex is proud to partner NAD in such an ambitious development” said Dr. Franz Riedlberger, Chief Technology Officer of Zetex, “Combining the technologies of Zetex and NAD will deliver an outstanding and highly-specified product. All the previous drawbacks of digital amplifiers are simply removed by use of digital feedback; power supply noise and output stage distortion are rejected and output impedance is very low. The result is the lowest available distortion and noise coupled with outstanding linearity, leading to a detailed and natural sound.”
http://www.diodes.com/zetex/?ztx=audio/audio03_6
Ultima modifica di Ivan il Ven 15 Mag 2009 - 12:35 - modificato 1 volta.
Numero di messaggi : 4915
Impianto : Ctrl+C, Ctrl+V.
Classe Z
Marchio registrato da Zetex Company. È un amplificatore digitale con un circuito di controreazione digitale.
http://www.diodes.com/zetex/_pdfs/literature/pdf/SCCLZBR2.pdf
http://www.zetex.com/7.0/index.asp
Barone Rosso- Moderatore
Insomma forse avremo un ampli NAD basato su tale tecnologia, speriamo però che non sia una esclusiva NAD e che magari forse un giorno anche la Sure possa offrire la sua bella schedina!
Numero di messaggi : 2531
Ho provato a cerca velocemente qualche "schedina" ma non ho trovato niente...
http://www.cdd.ru/repository/SCCLZBR1.pdf
qui la zetex spiega qualcosina... Bisognerebbe sviluppare un ampli del genere!
http://www.diodes.com/zetex/?ztx=audio/audio06
purtroppo non è ancora in vendita niente... se ho capito ha alcune peculiarità come il controllo via software del chip e entrata audio digitale!! il minimo di pezzi ordinabile è 400, bisognerebbe chiedere per una reference board (ne hanno di pronte)
Peccato che sia al di fuori della mia portata
speriamo in futuro qualcuno ci dia dentro
Numero di messaggi : 1176
Manda un email a questi:
http://www.sure-electronics.com/
Ormai ci avranno fatto il callo
entrata digitale nel senso che non serve più il DAC ?
wincenzo ha scritto:purtroppo non è ancora in vendita niente... se ho capito ha alcune peculiarità come il controllo via software del chip e entrata audio digitale!!
Sarà incorporato (forse DOPO l'amplificazione).
Giannast- Affezionato
- Data d'iscrizione : 08.05.09
Impianto : Oppo 980H, TA 10.1, Klipsh RF-35
In che senso "DOPO" !?!?!?!?
Numero di messaggi : 4290
Provincia : CA
il dac è incorporato, e se ho capito bene ha anche un controllore via usb per regolare dei filtri attivi interni! non è più come per il t-amp da digitale ad analogico a digitale a analogico, è tutto digitale, pure il feedback negativo (!!!)
cosa intendi?
Comunque interessantissimo il discorso del segnale tutto in digitale!
kingbowser ha scritto:il dac è incorporato, e se ho capito bene ha anche un controllore via usb per regolare dei filtri attivi interni! non è più come per il t-amp da digitale ad analogico a digitale a analogico, è tutto digitale, pure il feedback negativo (!!!)
feedback negativo? Deve essere un pessimo venditore ebay
scusate la battuta
ho sbagliato a scrivere, il feedback non è negativo (a quanto si può dedurre dal nome DDFA - DIRECT DIGITAL FEEDBACK AMPLIFIERS)
il feedback è una porzione di segnale amplificato che si fa rientrare nel primo stadio, quello di preamplificazione o di driver.
Nelle valvole si usa spesso quello negativo (cioè sottrarre una parte del segnale amplificato)
qui i pro ed i contro (in inglese)
http://en.wikipedia.org/wiki/Feedback_amplifier
era ora !!!! raga la prox versione di impianto definitivo: sorgente : penna USB :ampli , neanche una conversione........filtri crossover digitali.....e altoparlanti..........da saund
Si ma questa volta mika si faranno fregare come con il T.....prezzo di partenza 1K€ !!!!
scherzi a parte.....pare che il futuro sara' cosi.
gigirock- Interessato
- Data d'iscrizione : 17.02.09
Numero di messaggi : 72
Provincia : TuttoRego
Occupazione/Hobby : Lavoratore / Calcio
Impianto : 2 x Fenice 20 - Casse 2 vie DIY con woofer 16cm B&W lettore cd Pioneer Tarokkato croossover attivo Cabre. Lavatrice Candy
lo spero proprio!
il problema è che sembra un chip che vogliono vendere a caro prezzo...
Se va in pasto alla NAD penso saremo spolpati
forse c'è qualcosa in vendita, come dice il sito stereophile.com
questo è il bestio: Dreadnaught III
http://www.thetadigital.com/dreadnaught_iii_amplifier_info.shtml
non è propriamente economico - 3.250,00 dollarozzi
e se ho capito bene non fa manco uso del segnale interamente digitale se non con prima il loro DAC
Theta Digital, for example, had a static display on the floor of the Dome, but that didn't stop me from investigating what the company was up to. Taking pride of place on their stand was a relatively small power amplifier that nevertheless packed seven 150W channels of highly efficient class-D (PWM) power into its chassis. The Virtu PowerDAC features an all-digital signal path—it has digital inputs only, on four S/PDIF RCA jacks, for L/R Front, Center, L/R Surrounds, and L/R Rears (Sub is ignored)—and uses new technology from English company Zetex for converting PCM digital audio to the PWM format used to switch the amplifier's output devices.
kingbowser ha scritto:cioè sottrarre una parte del segnale amplificato
Sottrae una parte di segnale amplificato per distruggere retroattivamente gli eventuali disturbi. Ricordo che per un anno di elettronica all'ITIS si è parlato di questo magico fenomeno, che non mi è mai stato chiaro..........
Non credo che 'noi' amanti delle scatolette e degli opamp sostituitibili passeremo all'hi-fi monolitico, però certo qualcuno di noi spenderà soldi per provarlo come quarto impianto
mobius- Membro di riguardo
Numero di messaggi : 511
Provincia : Napoli
http://www.twice.com/article/CA6659474.html
altro che 1K$... 4.999$!!
Infami...
Infami...
Che se amplificano il segnale digital prima della conversione, come ad es. mi pare TACT e meridian, è meglio
ECCOLA:
il primo esemplare di amplificatore in classe Z
NAD M2 Direct Digital Amplifier
» T-Project 12: Amplificatore in classe A/B - Progetto LM1876 del Forum
» Dayton Audio DTA-100a
» Differenze tra Classe T e le nuove tecnologie in Classe D
» [CHIUSO] Usher R1.5 finale classe A 2x150W (ovviamente non tutti in classe A)_ Roma_ 1400€
» PREAMPLIFICATORE IN CLASSE "A" MONOLITICO PER IL MIO AMPLI IN CLASSE "A" PUSH-PULL "THE MINIMALIST"
Oggi alle 11:12 Da giuseppeneroli
Oggi alle 10:08 Da FilippoTN
Oggi alle 7:58 Da GAMBACORTA STEFANO
