[Venduto] DAC Sabre ES9023 Hifimediy Uscite digitali+ottiche+uscita cuffia - 80€ spedito
Il dac è questo http://hifimediy.com/index.php?route=product/product&path=62&product_id=84
[img][/img]
[img][/img]
Cito testualmente dal sito del costruttore:"This new DAC is build with with the same Sabre ES9023 chip as our USB DAC, featuring the same SABRE DAC technology. The ES9023 dac chip has a driver built in which outputs 2Vrms line level signal,and are able to drive low impedance loads like headphones, but at 32ohm the output power is reduced to 1Vrms, so connecting to an amp/preamp is recommended if your headphones are low efficiency.
It features two outputs, one of them going through a potmeter for controlling volume, while the other is straight out without the pot. The outputs are from the white connectors. Two cables with leads in the other ends are included.
It uses the CS8416 digital receiver and accepts up to 192k/24bit on all inputs.
This Dac has two LT1763 ultra low noise regulators, one for analog and one for digital.
This DAC chip does not have any DC voltage at it's output, eliminating the need of a DC coupling capacitor at the output.
With patented HyperstreamTM architecture and Time Domain Jitter Eliminator, the ES9023 delivers jitter-free studio quality audio with 112dB DNR.
On board trafo which can be wired for 115V or 230V. Simply connect mains voltage and you are ready.
The same trafo is used for both versions, only a switch (soldered) to change from 115V to 230V.
Two COAX and two OPTICAL inputs.
Switch for selecting inputs.
Input voltage: 230V (200V to 240V accepted)
PCB Dimensions: 120mm x 80mm (105mm including the connectors)
Height: 30mm Weight 300g".
Io ho messo il contenitore Galaxy Slim Line (22 euro ), i connettori di qualità ed uscita cuffia regolabile, Per 80 euro, spedizione col corriere inclusa, l'avrete a casa in due giorni. Altre foto a richiesta.
[img][/img]
[img][/img]
Ultima modifica di Orazio Privitera il Sab 2 Mar 2013 - 11:23 - modificato 3 volte. (Motivazione : precisazioni.)
Flightangel- CDP Expert
Numero di messaggi : 2361
Provincia : Catanzaro.
Impianto : Primary set-up:
Ampli: Accuphase E203
Slave set up:
Marantz cd 6004
Trends Audio ta10.2
Acoustical Rs3i
Re: [Venduto] DAC Sabre ES9023 Hifimediy Uscite digitali+ottiche+uscita cuffia - 80€ spedito
Ciao Andrews,
tutto bene?
Mi dai le misure dello scatolotto e, se ce l'hai, una foto del retro?
Ti (ri)chiedo : ma secondo te com'é rispetto ad altri dac quotati e + cari?
D'accordo che lo stai vendendo ma...sinceramente lo consigli?
....come vedi a lato il mio impianto é purtroppo andato in fumo ma da qualche parte devo pure cominciare!
..perché lo vendi?
grazie mille,
claudio
tutto bene?
..perché lo vendi?
grazie mille,
claudio
Numero di messaggi : 2616
Impianto : Cresce... ;-]]
H. Finn ha scritto:Ciao Andrews,
tutto bene?
+..perché lo vendi?
grazie mille,
claudio
Hai MP
Slave set up:
Marantz cd 6004
Trends Audio ta10.2
Acoustical Rs3i
Coda:
1) H Finn
2) Rincoman
1) H Finn
2) Rincoman
Slave set up:
Marantz cd 6004
Trends Audio ta10.2
Acoustical Rs3i
Coda + info
magnaco- Membro classe bronzo
- Data d'iscrizione : 20.06.10
Numero di messaggi : 1629
grazie delle info Andrews!
scusami ma lascio la coda
.......scusate ma son rientrato solo ora
VENDUTO al primo della coda. Chiudere grazie.
Slave set up:
Marantz cd 6004
Trends Audio ta10.2
Acoustical Rs3i
» HiFimeDIY Sabre ES9023 + TI PCM2706
» PRESO!! Nuovo Sabre DAC ES9023 uscita digitale e Toslink
» RM - venduto DAC USB Sabre ES9023 By Audiophonics - 30 euro
» [VENDUTO] FiiO E10 Dac Usb Ampli Cuffia € 60,00 Spedito
» (TO - VENDUTO) - HiFiMeDIY DAC USB Sabre come nuovo - Mai usato! 50 Euro + 5 di s.s.
Ieri alle 21:22 Da valterneri
Ieri alle 21:20 Da beppe61
Ieri alle 13:25 Da salvo93
