Nuovo DAC USB Firestone ILTW TENOR TE8802 + WOLFSON WM8740
http://www.firestone-audio.eu/shop/products/allproductslisted/iltw.php
In offerta a 199 euro non mi sembra male e poi questa ditta olandese (che produce in cina) sembra fare oggetti al di sopra di ogni sospetto, vedi il vecchio trasporto "Bravo" che in questi lidi ha bazzicato per un pò con ottime recensioni.
Ingresso: USB asincrono fino a 24/192
Uscite: I2S e RCA
Specifications
Amplifier Structure : Low pass filter with 2Vrms output
Power Structure : High frequency switching DC-DC regulator
USB Support Format :
16 Bit : 44.1kHz / 48kHz / 88.2kHz / 96kHz / 176.4kHz / 192kHz
24 Bit : 44.1kHz / 48kHz / 88.2kHz / 96kHz / 176.4kHz / 192kHz
Digital Interface : Direct I2S data format transmission (MAX support up to 192kHz-24bit over 1 meter CAT-5E cable)
Operation Mode : Support Adaptive and Asynchronous mode for audio stream transmission
Circuit Protect : Output short / over current protect
DAC Chip : WOLFSON - WM8740
USB Chip : TENOR - TE8802
LPF OP : NS - LM4562
Audio Performance (1kHz sine wave, 2Vrms output, 24-bit / 48kHz) USB Input
dB-Weighed Frequency response (From 40Hz to 15kHz) : 40Hz +0.02dB, 15kHz -0.12dB
Total frequency response is of course much wider from < 20Hz till far over 20khz
Noise level (1kHz, A-Weighted) : -106.7dB
Dynamic range (1kHz, A-Weighted) : 106.7dB
THD% : 0.012%
Stereo crosstalk : -102.7dB
Housing dimensions : 117 x 80 x 50 mm (D x W x H). Housing only without parts 'sticking out' like connector parts, swithes, etc.
Weight : 286 gram (without the external power supply)
Uscite: I2S e RCA
Specifications
THD% : 0.012%
voolkano- Membro di riguardo
Numero di messaggi : 530
Provincia : Andante con brio
Salotto
Player: Chromecast - Spotify
Amp: Pioneer a209R
Casse: Tedesche
Cameretta
Player: Raspberry - Librespot
Amp: IRS2092 autocostruito
Casse: Kef Coda 7
» Audio-gd realizza nuovi prodotti con ricevitore USB asincrono Tenor TE8802 24/192
» DAC con doppio Wolfson WM8740
» wolfson dac WM8741
» Dac Firestone Audio Spitfire MkII come nuovo a 150Euro+SS
» DAC USB molto economico e dalle buone prestazioni 29 Euro spedito
Oggi alle 1:33 Da giucam61
Ieri alle 21:22 Da valterneri
Ieri alle 21:20 Da beppe61
Ieri alle 13:25 Da salvo93
