[CHIUSO] Creek OBH11 SE ampli cuffie [NA] 150 euro
Posted - 29/01/2011 : 16:42:04
Come da oggetto, per passaggio a VHF1, vendo ampli cuffie Creek OBH11 Special Edition Revision B completo di superalimentatore Creek OBH2. L'ampli non ha un graffio ed è completo di scatola ed istruzioni originali.
Valuto permute, scambi, proposte, etc etc.
Note.
Preciso che per una curiosa scelta marketing la Creek lo ha chiamato 11 Special Edition lasciando intendere che si tratti di un upgrade del modello 11. In realtà si tratta di due prodotti radicalmente diversi, uno a chip e l'altro a discreti.
Qui il link al sito Creek
http://www.creekaudio.com/products/archive/obh11se.zip
qui una foto presa da internet
https://img.photobucket.com/albums/v76/huangyong/P1030092.jpg
qui la descrizione datane dal progettista:
As Chief Engineer of Creek Audio and the designer of both OBH-11 and OBH-11SE I can put some light on this topic. Both OBH-11SE "A" and "B" versions are fully discrete. Transition from "A" to "B" version was nesessary as the main MOSFET device used in the original OBH-11SE became obsolete. We do keep a quantity of these for service needs but further production was not possible. The replacement "B" version kept the original philosophy intact but replaced the output devices with bipolars and input device with a low-noise JFET. As a result the measured performance improved considerably - I do apologise for not updating the manual accordingly in time. Actual performance data are better than that of most OP-AMP based amplifiers. If there is an interest I can put here on the forum measured figures for OBH-11SE "B" rev.
Here the short measurements results summary for OBH-11SE rev "A" and "B". Note: all measurements but (5) referenced to 1mW output into 100 Ohm load = 0.316 V RMS.
1) Frequency response is the same for both amps - 3 Hz to 30 Khz at -1 dB point.
2) S/N ratio non-wtd 20Hz - 20kHz B/W is 78 dB for "A" rev. and 80 dB for "B rev. S/N ratio A-wtd is 80 dB for "A" rev and 86 dB for "B" rev.
3) THD from 20 Hz to 20 kHz are <0.02% for "A" rev. and <0.004% for "B" rev.
4) Output impedance - Output 1 - 100 Ohm, Output 2 or 1+2 - 220 Ohm for "A" rev. Output 1 - 30 Ohm, Output 2 or 1+2 - 68 Ohm for "B" rev.
5) Maximum output @ 1 kHz for 1% THD (Output 1 into 100 Ohm) - 2V "A" rev, and 3V RMS for "B" rev.
http://www.head-fi.org/forum/thread/9693/obh-11se-b-is-discrete
http://www.head-fi.org/forum/thread/6311/rega-ear-vs-grado-ra-1-vs-creek-obh-11se-vs-creek-obh-11-w-pic
http://www.head-fi.org/forum/thread/11172/another-question-on-creek-obh11-se
http://www.head-fi.org/forum/thread/14730/creek-obh11-se-alternative
http://www.head-fi.org/forum/thread/139872/creek-obh-11se-rev-b-appreciation-tread
Bruno
Note.
Bruno
Ultima modifica di nd1967 il Lun 30 Gen 2012 - 9:07 - modificato 2 volte. (Motivazione : Chiuso come da regolamento: >6 mesi)
b.olivaw- Membro di riguardo
Numero di messaggi : 506
Provincia : meteoropatico
Occupazione/Hobby : Robot
Re: [CHIUSO] Creek OBH11 SE ampli cuffie [NA] 150 euro
interessato...ma il prezzo???
glialberi- Affezionato
- Data d'iscrizione : 11.11.09
Numero di messaggi : 240
Provincia : ho finito di arrabbiarmi da parecchio tempo
Impianto : Nella stanzetta:
Miniwatt n3
sonic frontiers sft-1 transport
dac sotis isis
cavi alu Deantoni
acousticrevive rr77
in cerca del diffusore giusto ..
Altro impianto ..del mio amico
già, va indicato un prezzo, quand'anche trattabile.. e trattative in pvt
madqwerty- Moderatore
Naturalmente l'apparecchio ha un valore inestimabile perché è stato posseduto da me, direi almeno un milioneottocentotrentaduemila euro e quaranta centesimi. Per il bene della collettività audiofila accetto offerte intorno ai 150 euro senza offendermi
b.olivaw ha scritto:Naturalmente l'apparecchio ha un valore inestimabile perché è stato posseduto da me, direi almeno un milioneottocentotrentaduemila euro e quaranta centesimi. Per il bene della collettività audiofila accetto offerte intorno ai 150 euro senza offendermi
hahahahaha bellissima questa!!!
piero7- Membro classe oro
Volete lo sconto? Chiedete... hai visto mai
ps ho aggiunto anche il pre con telecomando sempre della stessa famiglia.
» [VENDUTO] Vendo ampli per cuffie Creek OBH-11 (80 euro)
» Due ampli e sei cuffie: impressioni di ascolto
» [CHIUSO] Cerco Ampli cuffie
» [CHIUSO] vendo cuffie AKG 272 hd euro 120
» [CHIUSO] Compro ampli valvolare MAX 70-80 euro.
Oggi alle 1:33 Da giucam61
Ieri alle 21:22 Da valterneri
Ieri alle 21:20 Da beppe61
Ieri alle 13:25 Da salvo93
