100W con 1.5V!
roby2k
pincellone
Marf
100W con 1.5V!
http://www.elektor.com/news/100-watts-of-audio-from-1-5-volts.1100209.lynkx?utm_source=UK&utm_medium=email&utm_campaign=news
http://www.audiumsemi.com/
Marf- Interessato
- Data d'iscrizione : 24.02.09
Numero di messaggi : 41
Impianto : purtroppo ancora sprovvisto -- a breve in arrivo!
Sorgenti: Philips Dvp3350/12, Marantz dr700, Aiwa XC-300, Pioneer PL-255, Pioneer RT-707, Tc-754 MaurarteTweaks, Behringer b2031a
Re: 100W con 1.5V!
Applications
Battery powered MP3 docking station speaker systems
Totally wireless speakers for home and PC audio
USB powered speakers
FPTV
Sound bars
Audio for automotive
Chi lo sa...nemmeno i Tripath erano nati con scopi audiophile...
Numero di messaggi : 3107
Provincia : Sinusoidale
Sarà vero? Mah...
100-W audio amp is 20 times more efficient than Class D chips
The AS1001 audio power amplifier IC is claimed, at normal listening levels, to be 20 times more efficient than competing devices, such as Class D amplifiers — and that without compromising audio quality. The company also claims that the amplifier is so efficient that battery-powered amplified loudspeakers can run for up to 10 months on a set of four C batteries, playing for three hours per day, vastly reducing CO2 from power generation and pollution from battery production.
The device operates from a nominal 1.5-V power supply and delivers 100-W peak power output. Applications include totally wireless speakers, home theater surround-sound speaker, and battery-powered travel speakers.
It also enables the development of smaller, cooler, mains-powered audio equipment. Housed in a 64-pin QFN package, the amplifier operates directly from a 0.8 to 1.8-V supply (compatible with, for example, alkaline primary cells and Ni-MH secondary cells). ($8 ea/1,000 — samples available now.)
Audium Semiconductor, Bristol, U.K.
Huw Davies 011-44-0-117 985 6950
info@audiumsemi.com
info@audiumsemi.com
Numero di messaggi : 2867
roby2k- Membro classe bronzo
Numero di messaggi : 1402
Provincia : CE
digitalmente corretti
Re: 100W con 1.5V!
Probabilmente sfrutta l'autoinduzione delle bobine per aumentare la tensione di uscita, esattamente come fanno gli alimentatori switching che accrescono la tensione di uscita.
Direi un ottima idea, se poi suona pure bene.
Pero avere 100w con 1.5v significa che la batteria deve poter dare fino a 66A, e una batteria del genere non mi sembra che esista.
Barone Rosso- Moderatore
Re: 100W con 1.5V!
si ma con una tensione piu alta, c'è bisogno di meno amperaggio...
gia a 12volt...
gia a 12volt...
ANDR3A101- Membro di riguardo
Numero di messaggi : 673
Provincia : mah se tira...
Lucio Cadeddu...
Re: 100W con 1.5V!
leggevo: "...Audium, previously known as M-Stream Technology..."
M-Stream:
http://www.broadcom.com/press/release.php?id=816609
tecnologia sviluppata da broadcom per i chip dei cellulari?? mah...
M-Stream:
Marf- Interessato
Re: 100W con 1.5V!
vedremo!!! speriamo non sia uno scherzo..
sarebbe "l'invezione dell anno" e farebbe tanti di noi..
dariolucc- Appassionato
Numero di messaggi : 473
Impianto : a metano nella macchina..
Re: 100W con 1.5V!
Ma i dati saranno affidabili?
F
F
ferdinando1200gt- Interessato
- Data d'iscrizione : 21.06.10
Numero di messaggi : 51
Impianto : copland + tannoy
» [VENDUTO] Sure TK2050 100W+100W 45€ +ss
» Sure TDA7498 2 x 100W
» Consiglio per Ampli da 100w per canale!!
» t-form amp Yamaha 100w A/B soli 200€
» Ho un toroidale da 100w 12v, come farne un alimentatore??
Oggi alle 11:54 Da fileo
