[DR5] [DR9] Muse - The 2nd Law (2012) CD vs HD
silver_85
kurt10
Muse - The 2nd Law (2012)HD
foobar2000 1.1.15 / Dynamic Range Meter 1.1.1
log date: 2012-10-29 19:08:42
Analyzed: ? / ?
DR Peak RMS Duration Track
DR9 -0.20 dB -11.78 dB 4:55 ?-01 Supremacy
DR9 -0.20 dB -11.63 dB 4:40 ?-02 Madness
DR9 -0.20 dB -11.02 dB 3:04 ?-03 Panic Station
DR10 -0.93 dB -16.60 dB 0:58 ?-04 Survival (Prelude)
DR8 -0.20 dB -10.66 dB 4:17 ?-05 Survival
DR8 -0.29 dB -10.79 dB 3:51 ?-06 Follow Me
DR8 -0.36 dB -10.90 dB 4:23 ?-07 Animals
DR9 -0.20 dB -12.28 dB 5:47 ?-08 Explorers
DR10 -0.20 dB -12.72 dB 4:40 ?-09 Big Freeze
DR9 -0.38 dB -12.31 dB 5:09 ?-10 Save Me
DR8 -0.20 dB -8.87 dB 3:03 ?-11 Liquid State
DR9 -0.21 dB -12.57 dB 3:48 ?-12 The 2nd Law Unsustainable
DR9 -0.20 dB -13.60 dB 5:00 ?-13 The 2nd Law Isolated System
Number of tracks: 13
Official DR value: DR9...
Samplerate: 96000 Hz
Channels: 2
Bits per sample: 24
Bitrate: 2624 kbps
Codec: FLAC
CD
log date: 2012-10-29 19:09:27
Analyzed: Muse / The 2nd Law
DR5 0.00 dB -7.95 dB 4:55 01-Supremacy
DR5 0.00 dB -7.43 dB 4:40 02-Madness
DR6 0.00 dB -7.25 dB 3:04 03-Panic Station
DR7 -0.03 dB -11.65 dB 0:58 04-Prelude
DR5 0.00 dB -6.90 dB 4:17 05-Survival
DR5 0.00 dB -7.21 dB 3:51 06-Follow Me
DR5 0.00 dB -7.05 dB 4:23 07-Animals
DR6 0.00 dB -8.42 dB 5:47 08-Explorers
DR6 0.00 dB -8.46 dB 4:40 09-Big Freeze
DR6 0.00 dB -8.50 dB 5:09 10-Save Me
DR4 0.00 dB -5.25 dB 3:03 11-Liquid State
DR6 0.00 dB -8.76 dB 3:48 12-The 2nd Law: Unsustainable
DR5 0.00 dB -9.57 dB 5:00 13-The 2nd Law: Isolated System
Official DR value: DR5.....
Samplerate: 44100 Hz
Channels: 2
Bits per sample: 16
Bitrate: 720 kbps
Codec: FLAC
kurt10- Membro classe bronzo
Numero di messaggi : 1625
Re: [DR5] [DR9] Muse - The 2nd Law (2012) CD vs HD
non vorrei dire, ma DR9 non è granchè neanche per un CD, figuriamoci per un file HD... c'è poco da mettere faccine sorridenti...
DR5 è poi da denuncia. Mio Dio... Tristezza a palate...
silver_85- Appassionato
- Data d'iscrizione : 16.11.11
Numero di messaggi : 412
Fiio E10 - Objective2
Purtroppo i Muse, gruppo che personalmente ADORO, hanno questo problema: le loro registrazioni fanno cagare a spruzzo.
La versione HD che roba è? DVD Audio? SACD?
EDIT: mi rispondo da solo, è la loro release in HD sul sito.
Numero di messaggi : 3781
- Impianto principale:
Testina: Ortofon Super OM40
Pre Phono: NVA Phono 1
Impianto in camera:
Sorgente: iMac 27"
Giradischi: Rotel RP-900
Testina: Ortofon 2M Red
Pre Phono: Cambridge P540
Ma la differenza è nettamente percepibile? (Chiedo direttamente a chi ha avuto modo di provare entrambe le versioni)
acvtre- Membro classe bronzo
Numero di messaggi : 1834
Provincia : Adelante
Dac: ???
Anche io sono un fan dei Muse, la qualità delle registrazioni non è il problema, qui il problema è la dinamica.donluca ha scritto:Purtroppo i Muse, gruppo che personalmente ADORO, hanno questo problema: le loro registrazioni fanno cagare a spruzzo.
Qualche giorno fa in un'intervista alla radio il cantante diceva che questo ultimo album, come i precedenti, è stato seguito da un famoso ingegnere del suono italiano di cui non ricordo il nome.
E' questo che proprio non capisco! Boh!
La qualità della registrazione degli album in studio è sempre stata ottima secondo me, ma la dinamica delle versioni CD è da suicidio, guardate qui:
http://www.dr.loudness-war.info/index.php?search_artist=Muse
Peccato veramente!
Per i vinili, invece, hanno sempre mantenuto una buona dinamica...
Tasso- Membro di riguardo
Numero di messaggi : 661
Provincia : Il bosco deciduo
- AMPLI: Marantz PM7001 KI
Ah ecco, questa è una cosa che mi interessa moltissimo: i vinili hai avuto modo di ascoltarli tutti? Come si sentono?
EDIT: e comunque a mio avviso il problema non è solo la dinamica: il suono è stridente, estremamente confuso, non riescono a distinguersi gli strumenti per bene e la voce è come "affogata" in questo caos.
Impianto in camera:
Sorgente: iMac 27"
Putroppo per ora niente giradischi per me!donluca ha scritto:Ah ecco, questa è una cosa che mi interessa moltissimo: i vinili hai avuto modo di ascoltarli tutti? Come si sentono?
Basta che guardi nel link precedente del database, gli album con scritto "Vinyl".
Ad esempio gaarda la differenza di "The Resistance":
CD http://www.dr.loudness-war.info/details.php?id=2459
Vinile http://www.dr.loudness-war.info/details.php?id=6510
Secondo me hai centrato perfettamente!donluca ha scritto:EDIT: e comunque a mio avviso il problema non è solo la dinamica: il suono è stridente, estremamente confuso, non riescono a distinguersi gli strumenti per bene e la voce è come "affogata" in questo caos.
Il suono confuso e gli strumenti che si confondono, la voce affogata in questo caos, sono proprio problemi di dinamica schiacciata.
La dinamica fornisce l'informazione spaziale al suono, senza poter distinguere il piano dal forte non puoi capire cosa è in primo e secondo piano.
Hai un ottimo orecchio!
Uhm.
Sinceramente la mancanza di dinamica io la colgo quando il suono dovrebbe diventare più forte ma invece rimane piatto, come se sbattesse su un "soffitto".
Cioè, io ho materiale con DR molto basso che però si sente comunque molto bene con strumenti ben separati, voce distinta e in generale con un buon posizionamento di ogni singolo strumento.
Poi magari può pure essere che una mancanza così drastica di dinamica porti ad un impastamento generale del suono ma su questo non mi sbilancio.
EDIT: e personalmente non trovo i vinyl rip affidabili perchè ci sono in gioco troppe variabili, ci sono anche modi per "barare" col range dinamico.
Impianto in camera:
Sorgente: iMac 27"
Anche questo è sicuramente un aspetto dello schiacciamento della dinamica.donluca ha scritto:Uhm.
Mi sta bene, io lo dico sempre che la Matematica è un opinione!donluca ha scritto:
Il Database Dr Loudness è curato da alcuni membri della Pleasurize Music Fondation, chiunque può pubblicare, ma non vedo quale interesse possa avere a taroccare i dati, sarebbe un assurdo controsenso.donluca ha scritto:
Per ora tutti i cd che ho comprato ed ho confrontato avevano esattamente gli stessi risultati.
Quoto, anche secondo me non è solo dovuto alla dinamica ma anche a precise scelte in fase di missaggio, soprattutto per la voce, che nei pieni è molto indietro rispetto agli strumenti. Questo almeno fino a Black Holes and Revelations, oltre non vado.
Numero di messaggi : 10085
The Resistance era un pò più ascoltabile, ma la registrazione continuava ad essere terribile imho.
Impianto in camera:
Sorgente: iMac 27"
Oggi alle 7:51 Da saltonm73
Ieri alle 22:00 Da valterneri
Ieri alle 21:58 Da morgana90
Ieri alle 15:42 Da philball1959
Ieri alle 12:56 Da Sanfilippo Roberto
» AKM VS ESS
» NAD 541i
» Lettore CD portatile
» Casse passive
» Casse passive
