JAVS X-DDC...Xmos usb
http://www.ebay.it/itm/JAVS-X-DDC-PC-Hi-Fi-Audio-Processor-DDC-24bit-192KHz-USB-2-0-/251024888611?pt=US_Home_Audio_Amplifiers_Preamps&hash=item3a723fd323
http://www.ne.jp/asahi/gonzaemon/audio/img/X-DDC-7.jpg
Britain's X-MOS company's X-CORE MICROPROCESSOR using
Supports the USB AUDIO CLASS 2.0 specification asynchronous mode.
16/24bit 44.1, 48, 88.2, 96, 176.4, 192KHz frequency support
ULTRA-LOW JITTER TCXO ± PPM CLOCK
Current status and playback frequency denoted front GRAPHIC LCM
JAVS only provide Windows OS installed driver and MAC OS X, Linux Kernel automatic support
At the Windows driver ASIO 2.2, S / PDIF PASSTHRU (DD / DTS), a digital capture (radiophonics recording) feature support
OPTICAL, COAXIAL, I2S (HDMI) 24bit/192KHz OUTPUT
24K GOLD 4-layers board and 1% resistor layer and the OS-CON capacitors using such advanced components.
USB bus power can be operated and support the separate external adapter (12V 1A) in connection support.
kurt10- Membro classe bronzo
Numero di messaggi : 1625
Re: JAVS X-DDC...Xmos usb
Mi sembra un prodotto di tutto rispetto ma... quant'è il prezzo della XMOS?
Numero di messaggi : 3781
- Impianto principale:
Testina: Ortofon Super OM40
Pre Phono: NVA Phono 1
Impianto in camera:
Sorgente: iMac 27"
Giradischi: Rotel RP-900
Testina: Ortofon 2M Red
Pre Phono: Cambridge P540
» Xiangsheng DAC-05A 24bit/192K XMOS USB oppure GUSTARD DAC-X9 DAC Dual WM8741/XMOS USB support DSD 384K 32Bit
» convertitore xmos
» Xmos i2s a 50€
» DAC PCM5102 e XMOS
» XMOS GUSTARD U12
» convertitore xmos
» Xmos i2s a 50€
» XMOS GUSTARD U12
Oggi alle 11:54 Da fileo
