Pbthal
jankovic
adicenter
cricchio
plankg
Pbthal
Avete mai sentito qualche rip da vinile fatto (in hd) da un certo "pbthal" ?
Procuratevene qualcuno e fatemi sapere.....
Sono incredibili........
Il suo ultimo set up:
Vinyl Ripping Process/Equipment
Vinyl Cleaning Process:
3 Liter Ultrasonic Cleaner (Tap water with Sporicidin) on custom rotating assembly at 1 RPM for one hour
Vacuum off with Nitty Gritty
AIVS Premium Record Cleaner Formula No. 15 applied with Mofi Brush while rotating on VPI 16.5
McCulloch MC-1275 Heavy-Duty Steam Cleaner applied with Mofi Brush while rotating on VPI 16.5
Vacuum off with VPI 16.5
L’Art du Son Record Cleaning Fluid applied with VPI Bristle brush
Whole Foods Deionized Water applied with Mofi Brush (Separate from AIVS Mofi Brush)
Flip record and repeat
Place record on Plate Demgnetizer
Turntable Equipment Profile:
VPI Scoutmaster with inverted bearing and 300 RPM motor
Trans-Fi ResoMat
Gingko Cloud 11 Vibration Control Platform
VPI Synchronous Drive System turntable motor speed controller and line isolator
Trans-Fi Audio Terminator T3Pro tangential tracking air bearing tonearm with Tomahawk Armwand
Soundsmith Sussorro Paua
Phono Stage Profile:
Musical Surroundings Phonomena Phono Preamplifier
Musical Surroundings Battery Power Supply
Analog/Digital Convertion:
RME ADI-2 =< ADAT =< E-MU 1212M
Adobe Audition 3.01 running on Windows XP in a Shuttle PC form factor
Post Processing Of Audio:
Run thru ClickRepair(if necessary) at level 7 with
Pitch Protection | off
Reverse | on
Simple
Resample to 96khz in Izotope Rx2 using the default preset
Manually listen to album in Adobe Audition cleaning any clicks/anomalies
Flac with Xrecode II for hi-rez files
Flac with Trader’s Little Helper for redbook files
Trans-Fi ResoMat
Reverse | on
Simple
plankg- Membro di riguardo
- Data d'iscrizione : 16.03.09
Numero di messaggi : 692
Re: Pbthal
Hai colto nel segno . . . anche se dubito se ne possa parlare.
cricchio- Appassionato
- Data d'iscrizione : 01.12.10
Numero di messaggi : 469
Impianto : Tolto dalla firma
Re: Pbthal
cricchio ha scritto:Hai colto nel segno . . . anche se dubito se ne possa parlare.
Tanto si son perse le tracce. O no?
Numero di messaggi : 2131
Impianto : Si
Re: Pbthal
no link no problem
Re: Pbthal
adicenter ha scritto:cricchio ha scritto:Hai colto nel segno . . . anche se dubito se ne possa parlare.
Rimane il grande lavoro fatto.
Io ne ho sotto mano circa 1200
Re: Pbthal
Urka
Re: Pbthal
Numero di messaggi : 3673
Re: Pbthal
non ti preiare....
sotto mano...non in mano
Re: Pbthal
Meno di 1200 ma li conservo come fossero vinili, religiosamente.
Un artista.
Impianto : Si
Re: Pbthal
Un artista.
Scusa, ma li hai tutti ?
Re: Pbthal
Un artista.
Una trentina, quelli che mi interessavano. Non so quanti ne abbia prodotti.
Impianto : Si
Re: Pbthal
Ho ascoltato The Wall dei PF (non in hd), il sergente Pepper, Supertramp, Black Sabbath tanto per iniziare...
ma la domanda che sorge spontanea è
ma come fanno ad essere così SUBLIMI questi files ?
ma allora non è vero che la musica digitale si sente necessariamente da schifo...
la fanno sentire così gli incapaci che la producono !
questioni interessanti...
Re: Pbthal
Oh temerario.plankg ha scritto:Ho ascoltato The Wall dei PF (non in hd), il sergente Pepper, Supertramp, Black Sabbath tanto per iniziare...
Tu ti addentri in territori ostili.
Odo già il rumor delle spade che escono dai foderi.
Impianto : Si
Re: Pbthal
Us and Them.. versione quadraphonic....
Storia di un minuto...alfredocatalani...
kurt10- Membro classe bronzo
Numero di messaggi : 1625
Re: Pbthal
Frank Zappa The Gumbo Variations
perfidoclone- Appassionato
- Data d'iscrizione : 09.03.10
Numero di messaggi : 364
Provincia : umore?
Occupazione/Hobby : nessun hobby tutte occupazioni
Ampli x cuffia:
TPaudio 2A3 modificato
Mhz Marrano NOS
VHF-N (il mio preferito)
Lighting in costruzione
Grado:
PS1000 Black Dragon Cable
GS1000
RS1
HP2i
HP2
AKG K1000
Magnum v.4 + Norse Audio
LCD2.0
Ultrasone Ed. 10
JVC DX1000
Denon D5000 Cocobolo Premium Wood Cup
Fidelio X1
Re: Pbthal
se ho capito bene, oltre ad essere rippati da vinile, sono anche elaborati con apposito software?
timido- Membro classe bronzo
- Data d'iscrizione : 21.11.11
Numero di messaggi : 1078
Impianto : denon 700 pma, b&w 685, V - DAC II
Re: Pbthal
timido ha scritto:se ho capito bene, oltre ad essere rippati da vinile, sono anche elaborati con apposito software?
Hai capito male.
Solo Click Repair, cioè vengono tolti gli eventuali crack tipici del vinili (se ci sono...).
Re: Pbthal
ho trovato questa lista del 2012.. e non e' ancora finito..
Final Master(2012)
ACDC - 1976 - Dirty Deeds Done Dirt Cheap (Albert APLP 020 LP Vinyl-Rip 24-96)
ACDC - 1980 - Back In Black (Atlantic SD 16018 Vinyl-Rip 24-96)
Aerosmith - 1976 - Rocks (JC 34165 Vinyl-Rip 16-44.1)
Black Sabbath - 1970 - Black Sabbath (Vertigo VO 6 Vinyl-Rip 24-96)
Black Sabbath - 1970 - Paranoid (Vertigo 6360 011 Vinyl-Rip 24-96)
Black Sabbath - 1980 - Heaven And Hell (Warner BSK 3372 Vinyl-Rip 24-96)
Cheap Trick - 1977 - In Color (Epic 34884 Vinyl-Rip 16-44.1)
Deep Purple - 1971 - Fireball (SHVL 793 Vinyl-Rip 24-96)
Deep Purple - 1972 - Machine Head (TPSR 7594 Vinyl-Rip 24-96)
Deep Purple - 1974 - Burn (EMI 1C 062-94837 Vinyl-Rip 24-96)
Dio - 1984 - The Last In Line (Warner Bros. Records - 9 25100-1 Vinyl-Rip 24-96
Fleetwood Mac - 1987 - Tango In The Night (Warner Bros. Records 25471-1 Vinyl-Rip 24-96)
Helloween - 1985 - Helloween (N 0021 Vinyl-Rip 24-96)
Helloween - 1985 - Walls Of Jericho (N 0032 Vinyl-Rip 24-96)
Iron Maiden - 1981 - Killers (FA 41 3122 1 Vinyl-Rip 24-96)
Iron Maiden - 1983 - Piece Of Mind (ST-12274 Vinyl-Rip 24-96)
Judas Priest - 1980 - British Steel (JC 36443 Vinyl-Rip 24-96)
Kansas - 1976 - Leftoverture (CBS JZ 34224 Vinyl-Rip 24-96)
Led Zeppelin - 1969 - I (Classic Records SD 8216 Vinyl-Rip 24-96)
Led Zeppelin - 1970 - III (Classic Records SD 7201 Vinyl-Rip 24-96)
Led Zeppelin - 1973 - Houses Of The Holy (Classic Records SD 7255 Vinyl-Rip 24-96)
Led Zeppelin - 1976 - Presence (Classic Records SS 8416 Vinyl-Rip 24-96)
Megadeth - 1990 - Rust In Peace (Capitol Records C1-91935 Vinyl-Rip 16-44.1)
Metallica - 1983 - Kill ’Em All (MRI 069 Vinyl-Rip 24-96)
Metallica - 1984 - Ride The Lightning (MRI-769 Vinyl-Rip 24-96)
Metallica - 1986 - Master Of Puppets (Elektra 60439-1 Vinyl-Rip 24-96)
Michael Jackson - 1982 - Thriller (Epic QE 38112 Vinyl-Rip 24-96)
Pink Floyd - 1973 - The Dark Side Of The Moon (Q4SHVL 804 Vinyl-Rip 24-96)
Pink Floyd - 1975 - Wish You Were Here (SHVL 814 Vinyl-Rip 24-96)
Pink Floyd - 1977 - Animals (SHVL 815 Vinyl-Rip 24-96)
Pink Floyd - 1979 - The Wall (SHDW 411 Vinyl-Rip 24-96)
Queen - 1986 - A Kind Of Magic (EMI EU 3509 Vinyl-Rip 24-96)
Rainbow - 1976 - Rising (Polydor OY-1-1601 Vinyl-Rip 24-96)
Rainbow - 1978 - Long Live Rock And Roll (Polydor POLD 5002 Vinyl-Rip 24-96)
Rainbow - 1979 - Down To Earth (Polydor 2391410 Vinyl-Rip 24-96)
Rush - 1975 - Fly By Night (Mercury SRM-1-1023 Vinyl-Rip 24-96)
Rush - 1977 - A Farewell To Kings (SRM-1-1184 Vinyl-Rip 24-96)
Rush - 1978 - Hemispheres (Mercury 9100 059 Vinyl-Rip 24-96)
Rush - 1981 - Moving Pictures (Mercury 6337 160 Vinyl-Rip 24-96)
Rush - 1982 - Signals (SRM-1-4063 Vinyl-Rip 24-96)
Rush - 1987 - Hold Your Fire (Polygram 832-464-1 Q-1 Vinyl-Rip 24-96)
Rush - 1989 - Presto (Atlantic 82040-1 Vinyl-Rip 24-96)
Rush - 2012 - Clockwork Angels (Roadrunner Records 1686-176561 Vinyl-Rip 24-96)
Saraya - 1989 - Saraya (Polygram 837 764-1 Vinyl-Rip 24-96)
Saraya - 1991 - When The Blackbird Sings... (Polydor 849 087-1 Vinyl-Rip 24-96)
Scorpions - 1976 - Virgin Killer (PPL1 4225 Vinyl-Rip 24-96)
Scorpions - 1979 - Lovedrive (SHSP 4097 Vinyl-Rip 24-96)
Slayer - 1986 - Reign In Blood (GHS 24131 Vinyl-Rip 16-44.1)
The Alan Parsons Project - 1980 - The Turn Of A Friendly Card (Arista DLART1 Vinyl-Rip 24-96)
The Doors - 1967 - Strange Days (EKS-74014 Vinyl-Rip 24-96)
Thin Lizzy - 1977 - Bad Reputation (Vertigo 9102 016 Vinyl-Rip 24-96)
Toto - 1982 - IV (Columbia FC 37728 Vinyl-Rip 24-96)
UFO - 1974 - Phenomenon (CHR 1059 Vinyl-Rip 24-96)
UFO - 1977 - Lights Out (CHR 1127 Vinyl-Rip 24-96)
UFO - 1980 - No Place To Run (CDL 1239 Vinyl-Rip 24-96)
Van Halen - 1978 - I (Warner Bros. BSK 3075 Vinyl-Rip 24-96)
Van Halen - 1984 - MCMLXXXIV (Warner 23985-1 Vinyl-Rip 16-44.1)
Whitesnake - 1984 - Slide It In (LBG 2400 Vinyl-Rip 24-96)
ultimate master
ACDC - 1979 - Highway To Hell (Atlantic SD 19244 Vinyl-Rip 24-96)
Black Sabbath - 1972 - Vol. 4 (Vertigo 6360 071 Vinyl-Rip 16-44.1)
Black Sabbath - 1973 - Sabbath Bloody Sabbath (WWA 005 Vinyl-Rip 24-96)
Deep Purple - 1970 - In Rock (SHVL 777 Vinyl-Rip 16-44.1)
Def Leppard - 1983 - Pyromania (Mercury 810308-1 M1 Vinyl-Rip 16-44.1)
Iron Maiden - 1980 - Iron Maiden (FA 41 3121 1 Vinyl-Rip 24-96)
Judas Priest - 1978 - Stained Class (CBS 32075 Vinyl-Rip 24-96)
Led Zeppelin - 1969 - Led Zeppelin II (Atlantic SD 8236 Vinyl-Rip 24-96)
Metal Church - 1985 - Metal Church (Elektra 960 471-1 Vinyl-Rip 24-96)
Nazareth - 1975 - Greatest Hits (Vertigo 6370 411 Vinyl-Rip 16-44.1)
Nirvana - 1993 - In Utero (Geffen Records DGC-24607 Vinyl-Rip 16-44.1)
Opeth - 2011 - Heritage (Roadrunner Records 1686-177051 Vinyl-Rip 24-96)
Pantera - 1992 - Vulgar Display Of Power (ATCO Records #7567-91758-1 Vinyl-Rip 16-44.1)
Pat Benatar - 1979 - In The Heat Of The Night (CHR 1236 Vinyl-Rip 16-44.1)
Rush - 1975 - Caress Of Steel (SRM-1-1046 Vinyl-Rip 24-96)
Saxon - 1980 - Strong Arm Of The Law (CAL 120 Vinyl-Rip 16-44.1)
Scorpions - 1984 - Love At First Sting (SHSP 24-0007-1 Vinyl-Rip 24-96)
Eagles - 1972 - Eagles (SD 5054 Vinyl-Rip 16-44.1)
Yes - 1983 - 90125 (Atlantic 790125-1 Vinyl-Rip 24-96)
Final Master(2012)
ultimate master
Provincia : umore?
Ampli x cuffia:
Mhz Marrano NOS
Grado:
GS1000
RS1
HP2i
HP2
AKG K1000
LCD2.0
Ultrasone Ed. 10
JVC DX1000
Fidelio X1
Re: Pbthal
Dove si possono acquistare?
magnaco- Membro classe bronzo
- Data d'iscrizione : 20.06.10
Numero di messaggi : 1629
Re: Pbthal
magnaco ha scritto:Dove si possono acquistare?
Non si possono acquistare, perchè nessuno li vende, nè sarebbe lecito farlo.
Mr. Pbthal ha semplicemente messo a disposizione della comunità degli appassionati di musica il suo notevole amore per il vinile (anche sotto forma di impegnativa e costosa apparecchiatura) trasferendo in digitale ad alta risoluzione tutta una serie di dischi aventi particolare valore per la qualità (spesso relativa) dell'incisione.
Pensate che, allo scopo, molti vinili di un certo valore (per l'edizione o per la rarità) gli sono stati addirittura appositamente spediti in prestito (ed anche regalati) da mezzo mondo.
Ora, la questione che volevo sollevare non è quella relativa al come procurarseli, ma quella ben diversa, di natura tecnica, sul come sia possibile che questi vinyl rip, se paragonati alle comuni edizioni in cd, possano suonare così meglio (o almeno così mi pare).
Qualcuno è in grado di dire la sua con cognizione di causa ?
Ciao e grazie
Ieri alle 11:38 Da philball1959
» FOZGOMETER
Ieri alle 11:28 Da philball1959
» Thorens TD 320 mkll
» Thorens rumore
» 2 Ampli e un Subwoofer
» Aiyima A07 - mi arriva oggi
» GAP nel TU SE
» Amplificatore per Kef q7
» Ritorno braccio
