[FIGO] Woo Audio WA7 Fireflies
beh, a me sembra figo, avessi soldi da buttare alla cieca sarebbe già in pre-ordine.
http://www.wooaudio.com/products/wa7fireflies.html
Specifications:
Single-ended, class-A, transformers output
Linear external high-performance power supply
Two 6C45 driver/power tubes
C-Media 6631 USB chip
TI PCM5102A 32-bit DAC chip
Headphones impedance : 8-600 Ohms
Input impedance: 100 Kilo-Ohms
Sampling rate: up to 32-Bit, 192kHz
Inputs: 1 Asynchronous USB2.0, 1 RCA
Outputs: 1 1/4" and 1 1/8" headphone outputs, 1 RCA (same connector as the input)
Max output: approx 1 watt @ 32 ohms
Frequency response: 11Hz to 27kHz, +/-0.5dB
Distortion: <0.03%
S/N: 95dB
Power consumption: 25W max
Mains supply: 100-120V, 220-240V, 50/60Hz, user selectable
Finish: Anodized aluminum
DC cord length: 4.25 ft or 1.3 m
Dimension: AMP: 4.8" L x 4.8" W x 5.1" H with glass
Features:
Handmade output transformer with Nickel Alloy core
32-Bit, 192kHz high resolution playback
Ultra-low jitter USB 2.0 runs on Asynchronous mode
High and low impedance output via switch
Open load protection will automatcially enagage to prevent the amp from damaging when no headphones are plugged in
Multi-functional switch for USB input, RCA input, and RCA output via D-A.
All-aluminum chassis with no screws visible from any viewing angles
High clarity tube protection glass
Multi-layer military grade PCBs
Customized driver for Windows Vista/XP/7/8
USB Audio Class 2.0 is natively supported by Apple OS X version 10.6.4 and above without installing driver
Specifications:
Distortion: <0.03%
S/N: 95dB
Features:
Numero di messaggi : 3693
Provincia : PU
diffusori - Stabilo 880 Woody
il resto è diy montessoriano
Re: [FIGO] Woo Audio WA7 Fireflies
A me piace questo http://www.wooaudio.com/products/wa234mono/
Comunque continuo a preferire dac + ampli separato, anche se i woo audio dicono che con le Grado facciano paura.
turo91- Membro classe argento
Numero di messaggi : 4587
Provincia : Sbilanciato
Tanta roba
MClean86- Membro di riguardo
- Data d'iscrizione : 12.01.11
Numero di messaggi : 796
Provincia : Cagliari
Sorgenti:
- Elac Miracord 50H
- NAD C540
DAC
- V-Dac II + Zetagi FT146
Ampli Integrato:
-Denon PMA-1060
Diffusori:
-RCF BR45
Oggi alle 11:41 Da mistervolt
Oggi alle 10:40 Da philball1959
Oggi alle 10:27 Da refrank71
Oggi alle 8:20 Da Marco Ravich
Ieri alle 21:59 Da Forfaber
Ieri alle 7:51 Da saltonm73
» AKM VS ESS
» NAD 541i
» Lettore CD portatile
» Casse passive
