ampli BIG JOE 2 ver 1.3 chi lo conosce?
Qualcuno lo conosce?..è classe D;AB?..bho..sotto una descrizione
Gigantic Sound in A Miniature Package
Don’t be fooled by the small size, the Big Joe stereo amp puts out a respectable 16 watts of power, the same as most single ended 300B tube amps.
The Big Joe is no wimp!
It can power speakers with a sensitivity of 88 db/W or better to surprising volumes with remarkable bass control and clean, non fatiguing highs.
You're guaranteed to be thrilled with the power and sound quality.
This is the most current Big Joe version, upgraded with a “BIG” heat sink to keep internal temps low. BJ is equipped with a volume control, so no preamp is required. Perfect for your main system or for an office/bedroom setup.
As with all Firestone components the build quality of the Big Joe is first rate.
The Rock Solid, all aluminum chassis is equipped with a massive heat sink and the machined face plate is black anodized and painted with the cool Big Joe graphic. The volume knob is machined from solid aluminum for a high quality look and feel.
Corsaro- Membro di riguardo
- Data d'iscrizione : 13.09.10
Numero di messaggi : 728
Provincia : dipende dal tempo
Impianto : Audio pro:
-Powersoft digam 2002
-SSL Mynx XR425 eq
Re: ampli BIG JOE 2 ver 1.3 chi lo conosce?
Big Joe? Mai sentito, che sia parente di questo?
Chiedo scusa, ma non ho resistito...
Numero di messaggi : 4098
Provincia : AN (Jesi)
DAC - Audio-gd NFB-1 ES9018
ampli - Denon PMA-1500ae
diffusori - Klipsch RB-81MKII
cavo USB - Audio-gd USB cable
cavi potenza Tw - Ricable U40
cuffie - HifiMan HE400i
cavo cuffie - Mogami W2534
..e bravo!!..c'ero arrivato prima io con il pensiero quando ho visto in rete quest'ampli..
-SSL Mynx XR425 eq
Dalle dimensioni sembrerebbe un classe D... ma dall'attenzione riservata alla dissipazione.... boh?
Numero di messaggi : 3935
Provincia : PT
DAC: Merging Hapi
PRE: Audio Research LS 27
AMPLI: Krell fpb 400cx
CAVI POTENZA Viablue sc4
AMPLI CUFFIE: Violectric V200
RE:ampli BIG JOE 2 ver 1.3 chi lo conosce?
C'è anche quello con Dac incorporato Big Joe III
http://www.unplggd.com/unplggd/realview-firestone-big-joe-3-digital-power-amplifier-092366
Numero di messaggi : 1849
Provincia : Varese Prov.
Sorgente: Oppo DV-983-H
Diffusori: Focal Aria 906
Cuffie: AKG K272HD ,AKG K340
Nella recensione del III dicono che è un classe D.
Ne parlano bene.
Ne parlano bene.
Switters- Membro classe oro
Numero di messaggi : 5072
Oggi alle 20:33 Da nerone
Oggi alle 20:17 Da RF14381
Oggi alle 11:41 Da mistervolt
Oggi alle 10:40 Da philball1959
Oggi alle 10:27 Da refrank71
Ieri alle 21:59 Da Forfaber
Ieri alle 7:51 Da saltonm73
» AKM VS ESS
» NAD 541i
» Lettore CD portatile
» Casse passive
