Il Resurrector, [fra riti vudu e polverine magiche]
La settimana scorsa è stato recensito su tnt audio uno strano attrezzo: il Resurrector. Reperibile solo su eBay:
http://www.tnt-audio.com/ampli/resurrector_e.html
http://myweb.tiscali.co.uk/nuukspot/decdun/gainclone_resurrector.html#top17
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260426840269&ru=http%3A%2F%2Fshop.ebay.com%3A80%2F%3F_from%3DR40%26_trksid%3Dm38%26_nkw%3D%2B260426840269%26_fvi%3D1&_rdc=1
Le descrizione su eBay è la più chiara:
The Resurrector compensates for a little understood problem known as
back-EMF (EMF being electro motive force). A loudspeaker driver works
on a similar principle to an electric motor. An electric motor consumes
electricity to make it run but can also be adapted to produce
electricity if some other source of power is used to turn it. What
happens with a speaker driver is that the voice coil is driven by the
voltage signal coming from the amplifier. The coil moves, and because
it is attached to the speaker cone, that moves too producing sound. But
the momentum of the cone moving means that after the signal from the
amplifier is stopped, it keeps moving and produces (generates) an
electrical signal that is fed back to the amplifier. This unwanted
signal gets into the feedback circuit of the amplifier and compromises
the original signal. The phantom driver used in conjunction with the
Resurrector produces the necessary feedback that is used for the
compensating the 'error' signal from the main speakers
Ultima modifica di Barone Rosso il Dom 14 Giu 2009 - 16:27 - modificato 2 volte.
Barone Rosso- Moderatore
Re: Il Resurrector, [fra riti vudu e polverine magiche]
Trovo molto esplicativa la frase che compare nell'annuncio di vendita su ebay:
I progettisti di motori elettrici la conoscono bene.
In italiano, in rete ho trovato questo intervento interessante, anche se non perfettamente pertinente:
http://www.audiocostruzioni.com/a_d/diffusori/esafono-stefano/esafono.htm
99 Euro (+ 20 di spese di spedizione) da investire in più in un gainclone non sono proibitivi, se il risultato è quello dichiarato...
Chi tra i DIYers e i costruttori nel forum proverà per primo?
Il "Resuscitatore" compensa un effetto poco compreso chiamato Forza Elettromotrice inversa...The
back-EMF (EMF being electro motive force)...[/size]
Numero di messaggi : 2889
Smanetton ha scritto:Trovo molto esplicativa la frase che compare nell'annuncio di vendita su ebay:Il "Resuscitatore" compensa un effetto poco compreso chiamato Forza Elettromotrice inversa...The
In efetti la descrizione su ebay, che non avevo letto è molto più chiara.
ebay ha scritto:
The
compensating the 'error' signal from the main speakers.[/size][/size]
Rispolvero questo 3d in quanto sembra essere passato quasi inosservato.
Nessuno lo ha provato?
roby2k- Membro classe bronzo
Numero di messaggi : 1402
Provincia : CE
digitalmente corretti
ho visto solo ora questo oggetto
ma qlc ne sa qualcosa di piu?
ANDR3A101- Membro di riguardo
Numero di messaggi : 673
Provincia : mah se tira...
Lucio Cadeddu...
dalla versione in inglese di dicembre scorso a quella in italiano di ieri su TNT
http://www.tnt-audio.com/ampli/resurrector.html
come sempre non ci capisco una bella m...za ma quando leggo che si hanno miglioramenti nella qualità musicale mi drizzano le orecchie.... a questo punto una domanda ma può funzionare anche con il Virtue ?? (ammesso che ci sia spazione nel case...)
fannaru- Membro di riguardo
- Data d'iscrizione : 19.04.08
Numero di messaggi : 933
fannaru ha scritto:dalla versione in inglese di dicembre scorso a quella in italiano di ieri su TNT
Funziona di sicuro, il problema è che è piuttosto ostico da montare, ma sopratutto ti servono dei woofer fantasma, che chiaramente dovrai collegare e nascondere da qualche parte per non sentirne il suono.
Quindi oltre al resurrector ti devi prendere un paio di woofer il più possibile simili a quelli dei tuoi diffusori (almeno penso che debbano essere simili), e poi montare il tutto.
La cosa più che altro mi incuriosisce ma all'idea di montarlo .....
Ieri alle 22:27 Da root
Ieri alle 22:01 Da root
Ieri alle 18:44 Da giucam61
Ieri alle 14:23 Da re134
Ieri alle 9:25 Da re134
» Amplificatore per Kef q7
Lun 13 Mag 2024 - 17:52 Da Guido1978
» Wiim Amp
» AKM VS ESS
» NAD 541i
