Abbiamo 11595 membri registratiL'ultimo utente registrato è petmar
I nostri membri hanno inviato un totale di 811220 messaggi in 52685 argomenti
dinamanu |
sportyerre |
giucam61 |
Nadir81 |
fritznet |
kalium |
MetalBat |
silver surfer |
mr.manalog |
valterneri |
dinamanu |
lello64 |
sportyerre |
giucam61 |
Nadir81 |
kalium |
fritznet |
nerone |
valterneri |
GP9 |
Stentor (20392) |
DACCLOR65 (19633) |
schwantz34 (15614) |
Silver Black (15525) |
nd1967 (12810) |
flovato (12509) |
Biagio De Simone (10294) |
piero7 (9854) |
fritznet (9458) |
wasky (9229) |
In totale ci sono 70 utenti in linea: 14 Registrati, 0 Nascosti e 56 Ospiti :: 2 Motori di ricercaAdriano Vin, ally, almo70, fritznet, GP9, MetalBat, modro, p.cristallini, pallapippo, pietro77, rabati, stepad, umberto.fiori, windopz
Audient ID4 e ID14
Audient ID4 e ID14
Vorrei sapere se c'e' molta differenza tra queste due e se sono buone caratteristiche:
questa è la ID 4 (140€)
DIGITAL TO ANALOGUE CONVERTER (DAC 1&2):
(measured under AES-17 at line outputs 1&2)
MAXIMUM OUTPUT LEVEL: +12 dBu (0 dBFS digital maximum)
DIGITAL REFERENCE LEVEL: +12 dBu = 0 dBFS
OUTPUT IMPEDANCE <100Ω
FREQUENCY RESPONSE: ±0.1 dB 10Hz to Fs/2 (flat to nyquist)
CROSSTALK: <-104 dBu @ 1kHz & 10kHz
THD+N @ -1dBFS (1kHz): <0.0015% (-96.5 dB)
DYNAMIC RANGE: 112 dB un-weighted
115 dB A-weighted
1/4" TRS Jack Tip (Hot), Ring (Cold) & Sleeve (Shield)
DUAL HEADPHONE OUTPUT:
MAXIMUM OUTPUT LEVEL: +12 dBu (0dBFS digital maximum)
VOLTAGE GAIN: +6 dB (optimised for loudness)
OUTPUT IMPEDANCE: <30 Ω Balanced
FREQUENCY RESPONSE: ±1.0 dB 10Hz to Fs/2 (load dependant)
CROSSTALK: -98 dBu @ 1kHz & 10kHz
THD+N @ -1dBFS (1kHz): <0.0012% (-98.4 dB)
DYNAMIC RANGE: 106 dB un-weighted
108 dB A-weighted
MAX LEVEL INTO 30ohms: +3 dBu, 0.008% THD+N, Power: 80mW
MAX LEVEL INTO 60ohms: +6 dBu, 0.005% THD+N, Power: 80mW
MAX LEVEL INTO 600ohms: +12 dBu, 0.0025% THD+N, Power: 31mW
1/4” TRS JACK: TIP (Left), RING (Right) & SLEEVE (Shield)
1/8” MINI JACK: TIP (Left), RING (Right) & SLEEVE (Shield)
ID14 (230€)
OUTPUT IMPEDANCE <100Ω Balanced
CROSSTALK: <-105 dBu @ 1kHz & 10kHz
THD+N @ -1dBFS (1kHz): <0.003% (-90.5 dB)
DYNAMIC RANGE: 114 dB un-weighted
117 dB A-weighted
HEADPHONE OUTPUT (DAC 3&4):
(measured under AES-17 at phones output)
CROSSTALK: -100 dBu @ 1kHz & 10kHz
THD+N @ -1dBFS (1kHz): <0.002% (-94 dB)
DYNAMIC RANGE: 108 dB un-weighted
111 dB A-weighted
MAX LEVEL INTO 30ohms: +4 dBu, 0.005% THD+N, Power: 101mW
MAX LEVEL INTO 60ohms: +5 dBu, 0.004% THD+N, Power: 64mW
MAX LEVEL INTO 600ohms: +13 dBu, 0.0025% THD+N, Power: 39mW
1/4” JACK: TIP (Left), RING (Right) & SLEEVE (Shield)
Ci sono anche le ID22 e 44 che saranno migliori...ma hanno caratteristiche che non mi servono e costano troppo per me.
115 dB A-weighted
108 dB A-weighted
ID14 (230€)
117 dB A-weighted
111 dB A-weighted
Re: Audient ID4 e ID14
Non entro nella discussione del DAC e ADC in quanto sono ignorante dell'argomento, ma ti servono gli ingressi Mic?
Le uscite per le cuffie sono "deboluccie", pochi mW, roba da smartphone.
Numero di messaggi : 2215
Occupazione/Hobby : R&D
Provincia (Città) : MI
Impianto : 230V Enel, Cotton fioc, Cyrus II + PSX, Pioneer BDP450, Thorens 166 BC +Cyrus Arm + Sumiko pearl, Cambridge Audio dacmagic 100 , DAC707 Superpro, Chromecast Audio, Teac TH380 Velodyne CHT8, Cambridge Audio MinX11 e MinX21
Mi interessa la sezione DAC principalmente e poi si...sono orientato per questo tipo di schede perchè produco musica,quindi mi interessa anche il lato microfono.
Quindi l'ampli per cuffie non è un granchè? io ho cuffie da 32 e una da 300 ohm ...non bastano quei mw?
Ho qualche dubbio con quelle da 300ohm@Mario Maione ha scritto:Mi interessa la sezione DAC principalmente e poi si...sono orientato per questo tipo di schede perchè produco musica,quindi mi interessa anche il lato microfono.
prima di acquistare questa scheda leggi in giro cosa dicono riguardo alla latenza
pare che non suoni affatto male ma per non avere scricchiolii devi mettere un buffer tanto alto da renderla inutilizzabile per la troppa latenza
con un budget così risicato guarda anche la scarlett 2i2 2gen che su questo piano parrebbe migliore
lello64- Membro classe oro
Numero di messaggi : 8480
Provincia (Città) : bologna
» [RM/NA] Vendo ONKYO A9010 - €150 + sp
» [PLEXIGLASS] consulenza elettrotecnica
» primo impianto hifi
» Diffusori IKEA Eneby
» puntina orfofon giradischi tensione d'uscita alta mV
» Musica di qualità per testare il proprio impianto
» [AN] RAMM Audio Elite 30 50cm
» ALIENTEK D8 [parte 2]
» Satorique 3 - Kit diffusori con SB Acoustic Satori
» A proposito del Milano Hi-Fidelity 2018...
» Aiuto Varie Regolazioni Giradischi
» Problema con Teac pls-75d 5.1
» Sostituzione altoparlanti tv da 10w Sony KD85/XD85xx . 65pollici
» Kef LS50 o...
» Pre Phono giusto per questa configurazione
» Dopo RaspyFi ecco Volumio - Music player audiofilo multipiattaforma
» Quale amplificatore? Diffusori AR66BX
» Fullrange 8ohm e supertweeter 6ohm?
» impianto liquida fanless ,ali lineari recuperati zigmahornet e cineserie varie.Una prova in divenire(500euro quasi tutto compreso)
» Project pre dac s2
» Consiglio trasporto USB/SPDIF sotto i 100 euro
» Vendo amplificatore integrato ibrido Peachtree iNova
» Consiglio su diffusori
» Relè Matsushita JD2-DC24V per ampli Proton introvabile...
» Sabaj A3 vs altri...(AD18, D8)
» CERCO crossower elettronico 3 vie
» Vendo crossover attivo AUDISON SXR4 a 200 euro trattabili
» Condensatore Procond MKP (Hiraga)
» LS3/5, così, giusto per parlare...
