[FOCUSRITE SCARLETT] Scarlett MixControl 1.9b4
Rilasciati il 28 Agosto i nuovi driver (anche USB) che risolvono parecchi problemi:
Sito: http://beta.focusrite.com/releases/scarlett_mixcontrol/
Mac and Windows New Features/Bug Fixes since previous release:
- Updates 18i8 firmware to r663. Fixes bug where settings can be lost after hardware power cycle.
New Windows Driver Features/Bug Fixes since 1.9b3
- Replaced USB Buffer Size with USB Performance Mode
- Additional streaming improvements
New Windows Driver Features/Bug Fixes since previous release:
- Updates USB 2 driver to version 3.1.8 beta.
- Improved compatibility with Pro Tools
- Numerous other bug fixes and structural improvements
- Comprehensive logging to facilitate future bug reporting
- Adds 1-channel WDM formats
- Adds multi-channel WDM formats
- Adds 24-bit WDM support
- Improves upgrade process from previous drivers
- Fixes sample rate change instructions from Scarlett MixControl
- Additional sample rate change fixes
- Fixes bug where sample rate mismatch can occur after sleep
- Fixes 16 bit audio streaming in Sound Forge 10
Important Note: Earlier Windows versions of Scarlett MixControl will not work with this driver, and this Windows version of Scarlett MixControl will not work with earlier versions of the USB 2 driver.
Please report any problems via your beta testing login or by emailing beta@focusrite.com, and you will be advised regarding capturing logging output to aid our developers.
» Focusrite Scarlett 2i2 90€
» [FOCUSRITE SCARLETT] Nuovi driver 1.9b2: finalmente WASAPI @ 24 bit !!!
» DAC Modi o Focusrite (Scarlett, Itrack)
» [FOCUSRITE SCARLETT] USB2 Driver 3.1.10
» Focusrite Scarlett 2i2: buon DAC a basso costo ?
Oggi alle 1:38 Da valterneri
Ieri alle 20:11 Da salvo93
Ieri alle 18:15 Da fileo
Ieri alle 17:06 Da skyufo
Ieri alle 11:35 Da Gedeone
» Pioneer PD 4100
» DAC su Raspberry e Volumio
» Consiglio per DAC
» Strani segni sul vinile
