Oggi alle 16:40 Da diechirico
Oggi alle 16:24 Da timo74
Oggi alle 16:09 Da Fabio Menozzi
Oggi alle 15:52 Da Albert^ONE
Oggi alle 15:50 Da Albert^ONE
Oggi alle 10:42 Da Nadir81
Oggi alle 8:09 Da lello64
Ieri alle 21:39 Da Albert^ONE
Ieri alle 21:32 Da Albert^ONE
Ieri alle 14:10 Da GP9
» quale stend?
» Quale micro hifi scegliere?
» Primo DAC
I nostri membri hanno inviato un totale di 812685 messaggi in 52805 argomenti
timo74
fritznet (9505)
In totale ci sono 49 utenti in linea: 6 Registrati, 1 Nascosto e 42 Ospiti :: 2 Motori di ricerca
Adriano Vin, diechirico, Fabio Menozzi, Nadir81, vinse, voolkano
[VENDO MI] Amplificatore CLASSDAUDIO 250W su 4ohm 120€
Messaggio  meral964 il Mer 2 Apr 2014 - 13:32
Vendo amplificatore 250W X 2 su 4ohm con modulo Americano della classdaudio CDA254 + scheda alimentatore e trasformatore toroidale da 300VA, il kit costa 199$.
I condensatori d'ingresso della scheda CDA254 sono stati sostituiti con dei condensatori Arcotronics al polipropilene.
Class D Audio Amplifier - 125 Watts RMS X Two Channel Stereo into 8 Ohm, 250W RMS X 2 into 4 ohms, and 500W RMS into 8 Ohms in Single Channel Bridge Mode.. Brand New and made by us here in the USA! Only 4 1/4" X 4 1/2" Ultra Clean & Thunderous Powerful Sound Lead Free & Energy Efficient This audiophile quality two channel Class D audio power amplifier or single channel in full bridge mode. All housekeeping power supplies are built-in so only a dual voltage +/- 42 to +/- 52 volt power supply is required. Features click and pop noise reduction, over/under voltage protection, over current protection, over temperature protection, and more! The new version of this amp has terminal blocks for input and terminal blocks for power supply and speaker connections. The provided heatsink is enough for most situations, but if you plan to push this amp really hard, then you will have to add additional heatsink or mount it to aluminum plate. Easy to mount... 9/16" standoffs and mounting screws are also included.
Ingressi RCA e Jack 3.5
Regolazione separata del volume per i singoli canali.
meral964
Data d'iscrizione : 10.06.08
Numero di messaggi : 765
Impianto : In Firma.
Re: [VENDO MI] Amplificatore CLASSDAUDIO 250W su 4ohm 120€
Messaggio  embty2002 il Gio 10 Apr 2014 - 15:25
scusa, ma è originale così dalla casa madre, a parte la sostituzione dei cap di cui parli?
è un giostraio?
embty2002
Data d'iscrizione : 29.11.08
Numero di messaggi : 957
Messaggio  ilfungo il Gio 10 Apr 2014 - 15:41
@embty2002 ha scritto:scusa, ma è originale così dalla casa madre, a parte la sostituzione dei cap di cui parli?
è un giostraio?
 Laughing è un kit, montato nella roulotte di un giostraio  Oki
qui l'implementazione del mio, http://www.tforumhifi.com/t42560-to-vendo-classdaudio-190-ss avessi denaro lo comprerei io per un bel biampling
ilfungo
Data d'iscrizione : 15.12.08
Numero di messaggi : 771
http://www.federicoporta.com
