Burson Timekeeper
Burson Timekeeper
http://www.bursonaudio.com/Burson_Timekeeper.html
Timekeeper It is a 75W per channel Class-AB power amp which can be bridged into 250W per channel in Mono-Block configuration. Measuring 265 x 250 x 80 mm the Timekeeper is the same size as the HA-160D & Conductor. The RRP of the Timekeeper will be 2200USD.
The Timekeeper is very important to us and it has taken us nearly 5 years to get it right. It is unique in the follow ways.
1. There is a growing community of desktop audiophiles. These people are looking for high-end equipment that are desktop size. And at this compacted size, no other amplifier can compete with the Timekeeper. To put this into prospective, all other power amps of this size are Class-D amps. Class-D amps were designed for the car audio and sound horrible . The only other properly designed amplifier of this size is the Korean Bakoon 11R and they could only achieve 15W per channel and priced at 7,000USD.
2. Usually, Mono-Block power amps only accept XLR (balanced) input. This means that if a customer want to upgrade to Mono-blocks then he much also change his DAC to one with XLR outputs and his Preamp to one with XLR input/outputs. As you can imagine, it could be an expensive exercise. Our Timekeeper however can accept both RCA and XLR input even when bridged. This means the customer can keep his beloved DAC and preamp when upgrading to Mono-Block with the Timekeeper. The Timekeeper is probably the first in the industry to achieve this function.
kurt10- Membro classe bronzo
Numero di messaggi : 1625
Re: Burson Timekeeper
E io sbavo... per fortuna che 2200 dollari mi ci terranno lontano va.
A me la roba che fa paura è quella "affordable".
Numero di messaggi : 3781
- Impianto principale:
Testina: Ortofon Super OM40
Pre Phono: NVA Phono 1
Impianto in camera:
Sorgente: iMac 27"
Giradischi: Rotel RP-900
Testina: Ortofon 2M Red
Pre Phono: Cambridge P540
http://www.tnt-audio.com/ampli/burson_timekeeper_e.html
Rece su TNT-audio
Rece su TNT-audio
pktgod- Membro di riguardo
- Data d'iscrizione : 08.03.11
Numero di messaggi : 641
Provincia : Parma (Noceto)
è un prodotto che mi ha stregato da subito anche per la doppia possibilità di usarlo per biamplificare in orizzontale o verticale oppure come due moonoblocchi per diffusori tosti
bello bello bello specie in coppia col Conductor
Doc_Zero- Affezionato
- Data d'iscrizione : 02.07.13
Numero di messaggi : 232
Provincia : RM
Impianto : Norma Revo IPA-140
Oppo BDP-105D
Opera Quinta SE
Schiit Bifrost Multibit
Pioneer PL-630
Pro-Ject Phono Box RS
Eh si... Poi in un discorso di pulizia del segnale, con un cavo USB e un RCA colleghi convertitore,DAC,pre e finale... Con una sinergia garantita.
Veramente interessante.
se il conductor avesse anche le uscite bilanciate sarebbe ancora meglio
Provincia : RM
Oppo BDP-105D
Opera Quinta SE
Pioneer PL-630
In effetti questa scelta non l'ho capita molto...
nel conductor non vedo una struttura realmente bilanciata a cominciare dall'alimentazione quindi inserire delle uscite XLR sarebbe stata un pò una presa per il culo
Provincia : RM
Oppo BDP-105D
Opera Quinta SE
Pioneer PL-630
» Burson Audio Timekeeper Finale di potenza 2,400.00 EUR
» Vendo Burson Audio DA-160 Euro 500 s.s. incluse
» DAC Burson
» Burson P-100
» Burson supreme V5
» DAC Burson
» Burson P-100
» Burson supreme V5
Oggi alle 22:32 Da valterneri
Oggi alle 19:06 Da lello64
Oggi alle 17:41 Da RF14381
» WHARFEDALE Aura 2
Oggi alle 9:55 Da giucam61
Oggi alle 4:52 Da Gionni
Oggi alle 0:07 Da arthur dent
Ieri alle 23:19 Da bertuc79
Ieri alle 17:25 Da lello64
