VENDUTO (PD) Audio Analogue Donizetti - Finale dual mono - 350 euro + ss
Vendo Audio Analogue Donizetti in perfette condizioni!
Finale a stato solido dual mono dal suono pieno e raffinato. Doppio trasformatore, 60 Watt su 8 ohm, 120 Watt su 4ohm, cablaggi interni XLO e Kimber Kable... Un vero gioiellino!
Vendo a 350 euro + s.s.
Priorità ritiro a mano
Spedisco con corriere (consegna 24/48h)
Descrizione:
The Donizetti power amplifier is born with those characteristics that have become synonymous of Audio Analogue: style, quality and that transparency, musicality, and sonic purity typically High-End with a remarkable value for money. The totally dual-mono structure with independent power supplies for each channel starting from the mains supply give an excellent separation minimising undesirable crosstalk effects. Select components, using 0.1% tolerance metal-film resistors in critical places and polypropylene and polystyrene capacitors ensure an extremely low noise floor; the two massive toroidal transformers (one for channel) totalling 400VA with a third for all other functions, almost 60,000mF of filter capacitance and no less than eight power transistors provide a current reserve sufficient for peaks and transients and even for the most difficult speakers. All connectors are anti-corrosion gold-plated, from the RCA signal sockets to the robust speaker-output binding-posts: two for channel in order to ease bi-wiring connections to speakers that offer this facility.
The internal wiring is done using XLO ElectricTM e Kimber KableTM products. The chassis with its 1 cm thick, satin black or silver aluminium-alloy give the amplifier a very stylish, sober appearance, capable of blending well into any system.
Specifiche:
Total Harmonic Distortion (THD): < 0.1% @ 60w / 8ohm / 1kHz
Frequency Response: 20Hz - 20kHz ± 0.1 dB; 4Hz - 230kHz @ - 3dB
Nominal Sensitivity (1V Out): 1Vrms @ 60 W / 8 ohm
Input Impedance: 39 kohm / 100 pF
Channel Separation: 100 db
S/N Ratio: > 110 db (linear) / > 110 db (weighted)
Output Power: 2 x 60 W @ 8 ohm / 2 x 120 W @ 4 ohm / (2 x 170 W @ 2 ohm) / 1kHz
Slew Rate: > 10 V / µs
Damping Factor: > 100 @ 1kHz / 8 ohm / 1 W
Nominal Voltage Supply: 115 / 230 VAC, 50 / 60 Hz
Dimensions (W x H x D): 44.5 x 8.5 x 34.3 cm
Weight: 10,9kg
Discussione con foto dell'oggetto in vendita: https://www.tforumhifi.com/t29454-audio-analogue-donizetti?highlight=donizetti
Numero di messaggi : 1502
Provincia : Padova
Sorgenti: Asus EEEPC
Dac: Micromega Mydac
Pre: Pass B1 Buffer
Finali: Pass Mini Aleph
Cavi:
usb: Wireworld Ultraviolet
segnale: JPS clone
potenza: Audioquest FLX 14.4
alim: Elecaudio CS-331B
VENDUTO
Venduto altrove!
Chiedo scusa per essermi dimenticato di specificare che era in vendita anche su altri siti.
Provincia : Padova
Pre: Pass B1 Buffer
Cavi:
segnale: JPS clone
» [VENDUTO] finale GAINCLONE KIT AUDIOSECTOR DUAL-MONO [250€]
» [CHIUSO] Gainclone Finale Dual Mono by HEAO-Dreamflyer - 250 euro
» [VENDUTO] Due Finali dual Mono gainclone lm 3875 euro 150+ss
» [VENDUTO] Gainclone due telai dual mono (190 euro compresa spedizione)
» [VENDUTO] Gainclone Audiosector dual mono classic, tutto il necessario 80 euro
Oggi alle 13:01 Da salvo93
» WHARFEDALE Aura 2
Oggi alle 9:55 Da giucam61
Oggi alle 9:29 Da giucam61
Oggi alle 8:36 Da RF14381
Oggi alle 4:52 Da Gionni
Oggi alle 0:07 Da arthur dent
Ieri alle 23:19 Da bertuc79
Ieri alle 21:08 Da lello64
Ieri alle 17:25 Da lello64
» SACD e ascolto dsd nativo
