[HELP] Scelta mini-diffusori per posizionamento difficile
Ragazzi, purtroppo la mia postazione di lavoro è cambiata e non posso più usare le amate Canton GLE-70
Ora sto su un'affare del genere:
...quindi sono costretto a mettere i diffusori sul rialzo per il monitor.
Provvisoriamente l'ampli sarebbe il "famoso" Quiet Pegasus A-11T "custom" (fù di valvolas)...
Come sapete sono un'amante delle casse in sospensione pneumatica, ma visto che ora non ho pareti da sfruttare, voi cosa consigliate ?
...ovviamente mi va - più che - bene anche qualcosa di vintage...
Dimenticavo: budget max 100€
Re: [HELP] Scelta mini-diffusori per posizionamento difficile
Primo interessante auto-suggerimento (spulciando la rete): NHT SuperZero 2.0
...il problema è: dove li trovo ???
EDIT: fermi tutti, questi costano 99$ CADUNO ! Fuori budget !
The new NHT SuperZero 2.0 is a true-high end mini-monitor that builds on the merits of it's predecessor and dare we say, improves upon them. Transparency, detail, "walk-around the stage" realism, it's all there, and so much more.
At just 9" Tall x 5" Wide x 5.5" Deep the SuperZero 2.0 is small. really small. Unlike most small speakers, which try to fool you with boomy, pseudo-bass from a port, the Super Zero 2.0's acoustic suspension (sealed) enclosure skips the bass and focuses on making beautiful, lifelike midrange and high frequencies. Just like the original.
Magic Box - Build quality is stunning too. The compact, well-braced cabinet is naturally strong and stout. Stronger than larger boxes. As a result, it doesn’t have the to deal with the box vibrations that interfere with the critical midrange performance of its big-boy counterparts. The speaker's narrow front face is almost all speaker, so there's no wide baffle to interfere and interact with the Super Zero 2.0's output.
Better - No mere re-make, the SuperZero 2.0 makes some subtle improvements to the original Super Zero design. Specifically, we found that if we added an itsy-bitsy coil of wire to the crossover in just the right place we could make the tweeter roll off a bit faster (12dB/oct), effectively blocking more of the bass that tries to sneak into the tweeter without negatively impacting its response. This small crossover change significantly lowers the tweeter's distortion, improves power handling, and makes the lil’ bugger sound even better than the original.
In-Side – The SuperZero sports a 4.5” long throw pulp cone woofer and a 1” silk dome tweeter. As mentioned above it features a 2nd order crossover (12 dB/octave) for both the midrange and tweeter.
Out–Side – The SuperZero is finished in a beautiful black gloss laminate. Its grill is removable for those moments when you want to light candles and listen at the apex.
ciao, queste sembrano interessanti:
http://annunci.ebay.it/annunci/audio-tv-e-video/roma-annunci-aurelio-boccea/canton-hc100-satelliti/36721476
oppure queste un pò fuori budget ma con un minimo di contrattazione ti dovresti avvicinare
http://annunci.ebay.it/annunci/audio-tv-e-video/roma-annunci-roma/casse-diffusori-canton-fonum-50/35780297
http://annunci.ebay.it/annunci/audio-tv-e-video/catanzaro-annunci-catanzaro/diffusori-canton-fonunm-20/30237265
ma se le trovi usate le Mosscade 502 sono ottime. Io le uso vicino al computer...grande soddisfazione
Edoardo- Membro classe bronzo
Numero di messaggi : 1213
IMPIANTO PRINCIPALE
IMPIANTI SECONDARI
Grazie per i suggerimenti, ragazzi.
Il problema è che lo spazio a disposizione a fianco del monitor è al massimo è 18x20 !
Ci vuole qualcosa di piccolo !!!
non puoi mettere due mensole sul muro dietro lo schermo per recuperare un po' di spazio per poter mettere qualcosa di più largo ?
nicommush- Membro di riguardo
Numero di messaggi : 898
Impianto : ---
diffusori
visto lo spazio massimo che hai e che avevi delle canton guarda queste (è solo un esempio ......... puoi anche metterti il sub ..... si trova anche quello facilmente ....
http://www.ebay.it/itm/2-x-CANTON-Plus-S-TOP-HiFi-LAUTSPRECHER-Haupt-Stereoboxen-/150941844763?pt=DE_Lautsprecher_Martin&hash=item2324d5c51b
Ferruccio
Ferruccio
Ferruccio- Affezionato
- Data d'iscrizione : 17.03.11
Numero di messaggi : 169
Se prendi in considerazione l'autocostruzione, e se hai la parete libera, potresti costruire dei diffusori "piatti" (dei "quadri" spessi 10-12cm) da appendere alla parete dietro la postazione. Magari con i baffle inclinati verso il punto di ascolto.
Diffusori di questo tipo li ho visti e sentiti l'anno scorso al TAV, non suonavano affatto male IMHO (considerando l'uso che ne faresti).
Switters- Membro classe oro
Numero di messaggi : 5072
Eh, se fosse così facile...
Purtroppo dietro al monitor (davanti alla postazione) non c'è la parete !
Per questo dicevo che la cosa è complicatuccia...
Comunque Sarei tentato dalle Canton HS 100... vediamo un po' !
Marco Ravich ha scritto:Eh, se fosse così facile...
Lavori in terrazza???
» Scelta difficile diffusori da scaffale
» Posizionamento/scelta diffusori
» Scelta diffusori per ambiente piccolo e posizionamento critico.
» Scelta mini diffusori
» Scelta difficile....
Oggi alle 13:23 Da Quaiozi!
Oggi alle 13:01 Da salvo93
» WHARFEDALE Aura 2
Oggi alle 9:55 Da giucam61
Oggi alle 4:52 Da Gionni
Oggi alle 0:07 Da arthur dent
Ieri alle 23:19 Da bertuc79
Ieri alle 21:08 Da lello64
Ieri alle 17:25 Da lello64
» SACD e ascolto dsd nativo
