Sembra il Dac Superpro (ma costa 40 eu)
+5
Cella
c3kkos
brasa
Alessandro LXIV
Artinside
9 partecipanti
E' molto simile al Superpro, queste le specifiche:
Specifications
Based on CS4344 DAC chips and one CS8416 digital receiver from Cirrus/ CM102AH as USB receiver
Power supply: DC 6~24V(12~18V recommended)
Input: Coaxial *1/ USB *1/ Optical *1, One 3.5mm microphone
Output: one group of RCA & 3.5mm headphone out
Frequency response: 20Hz- 20Khz
SNR: RCA out-- (-90DB)
Support sampling rate: 32kHz,44.1kHz,48kHz,88.2kHz,96kHz,192KHZ
Size: 770mm * 64mm *25mm(L*W*H)
Queste quelle del superpro:
D/A Receiver chip CS-8416, D/A converter chip, CS-4398 (24-192KHZ )
Dual LT1364C OPAMPS for analog output circuit
Optical digital input
Coaxial Digital Input
USB input (USB 1.0 and 2.0 compatible)
USB inputs runs derect I2S to D to A through CS 4398 chip resulting to better transparency and definition
CM-108 USB receiving chip
S/PDIF (RCA) Digital output active when USB is connected
S/PDIF (RCA) Digital input active when USB is *not* connected
Standard RCA analog output plugs
Output voltage ± 3.5V / 400mW
Audio output: 24bit/48khz (44.1Khz)
Dynamic range: 120dB
Signal to noise ratio: 107 dB
40 eu spedito:
http://cgi.ebay.it/Pro-HiFi-24bit-USB-DAC-digital-sound-card-CM108AH-192kh-/300591945605?pt=UK_AudioTVElectronics_HomeAudioHiFi_Amplifiers&hash=item45fcad1785#ht_4388wt_905
Specifications
40 eu spedito:
Numero di messaggi : 3182
- Sorgente: Jvc xv-n680
Pre: Minimalist autocostruito
Numero di messaggi : 5173
Re: Sembra il Dac Superpro (ma costa 40 eu)
L'avevo puntato anche io ma quello che non ho capito è se in Usb trasporta il segnale a 24/192 o se è solamente in Optical/Coax.
Qualche notizia in più?
P.S. Mi puzzava questa riga: This mini DAC unit is base on CS4344 DAC processor /CS8416 Digital receiver and CM108AH USB receiver,It can handle 24bit/192Khz audio via coaxial/optical inputs
brasa- Interessato
- Data d'iscrizione : 01.01.11
Numero di messaggi : 77
Provincia : :)
Occupazione/Hobby : Informatica, Auto e moto, Audio
Impianto : Amplificatore S.M.S.L. SA-36 ( TA 2024 ) Alimentatore Pincellone + Diffusori KEF Coda 7 + DAC DAC DIR9001 PCM1793 OPA2134 by S.M.S.L. + Musiland Monitor 02 US
beh basta cercare il datasheet del controller usb:
http://www.cmedia.com.tw/ProductsDetail.aspx?C1Serno=2&C2Serno=2&C3Serno=6&PSerno=7
volete sapere la mia?
per me è una ciofeca..
troppo "general purpose" e il controllo volume digitale non mi piace per nulla.
OVVIAMENTE è una valutazione "a naso"!
mod.
aggiungo che non è citata la capacità di trasporto del chip in questione, solo questo, che però, potrebbe essere sufficiente:
48K / 44.1KHz Sampling Rate for Both Playback and Recording
mod.
c3kkos- Interessato
- Data d'iscrizione : 07.06.11
Numero di messaggi : 88
Impianto : Scythe SDA-2100 revB
B&W DM602 S3
Marantz CD6000 OSE
experimental use of atv2
È la prima versione del SuperPro come scritto sul PCB e a questo prezzo è un'affare per chi non ne ha già uno migliore.
Poi non capisco il commento sul volume digitale: se usi il DAC in USB hai ben altro di cui preoccuparti, prima dell'unico problema risolvibile via software.
Cella- Membro classe argento
Numero di messaggi : 2715
Impianto : Trends TA-10.2
Kingrex T20U
Topping TP32
Muse MU-T15, MU-15 MK2
Ovviamente se prima di aprire il becco guardavo bene i condensatori era meglio!
Quelli in uscita, elettrolitici per giunta, andranno in serie a Quelli dell'amplificatore, peggiorandone la risposta. Meglio sostituirli ma lo spazio all'interno del mobile non lascia molte alternative, dato che la capacità dovrà essere elevata.
Kingrex T20U
Topping TP32
Tra non molto dovrei prendere un netbook per storare musica e usarlo come sorgente, insomma se si vuol spendere poco e avere una resa decorosa quest'oggettino potrebbe fungere....
Funzionerà di sicuro, il punto è che se serve un DAC USB, siccome questo non brilla, le alternative economiche non mancano.
Kingrex T20U
Topping TP32
tipo il FiiO
c3kkos- Interessato
B&W DM602 S3
Marantz CD6000 OSE
Non lo so; ho l'abitudine di non scrivere su ciò che non ho mai avuto tra le mani.
Kingrex T20U
Topping TP32
Ciao Christian, ti andrebbe di indicare qualche alternativa pari-prezzo? graziechristian.celona ha scritto:Funzionerà di sicuro, il punto è che se serve un DAC USB, siccome questo non brilla, le alternative economiche non mancano.
Si vede che ho tempo da perdere?Alessandro LXIV ha scritto:Segugio...
OT- Non centra una mazza.... ma guardando la tua foto con un bel giaccone invernale, Gavino, mi viene nostalgia per il fresco. Sai io odio il caldo... e sto Settembre da 30° mi fa sudare.... sarei dovuto nascere in Svezia.
Numero di messaggi : 3935
Provincia : PT
DAC: Merging Hapi
PRE: Audio Research LS 27
AMPLI: Krell fpb 400cx
CAVI POTENZA Viablue sc4
AMPLI CUFFIE: Violectric V200
Dipende anche dai gusti, comunque se vai su eBay e cerchi DAC USB trovi più di 600 risultati, anche se molti privi di box esterno.
Kingrex T20U
Topping TP32
grunter ha scritto:OT- Non centra una mazza.... ma guardando la tua foto con un bel giaccone invernale, Gavino, mi viene nostalgia per il fresco. Sai io odio il caldo... e sto Settembre da 30° mi fa sudare.... sarei dovuto nascere in Svezia.
, Non se ne può più di questo caldo (magari tra un pò lo rimpiangeremo...) .In quello foto sono a novembre nella mia cittadina natale, Tempio Pausania, con temperature tra 0 e 2 gradi (è a 700 metri)
ma rispetto al fiio è meglio o peggio?
mudhoney- Novizio
- Data d'iscrizione : 09.05.12
Numero di messaggi : 17
Impianto : TCC TC-754 + Fenice MKII + ?
Se date un occhio al datasheet del 4344 vi renderete conto che non è nemmeno lontanamente paragonabile al 4398.
@mudhoney
Quale Fiio?
@mudhoney
Quale Fiio?
Patrick- Musicista/Fonico
Numero di messaggi : 6121
Provincia : Disforico
PC
Onkyo A-9355
Tannoy Precision 8
Cuffie, cuffie, cuffie
mudhoney- Novizio
mudhoney ha scritto:il Fiio D5
Sulla carta, stando semplicemente ai dati, dovrebbe essere migliore quello preso in esame in questo thread.
PC
Onkyo A-9355
Tannoy Precision 8
Dunque ho preso il dac in questione e sta suonando da un paio di ore sul mio impianto attualmente composto da maccanica philips cd 930 fenice 20 e diffusori monovia con monacor sp 155 x...in tqwt...preso da singapore e arrivato in 15 giorni..oggi me lo porta la postina con 11 euro di dazi..vabbe' e la prima volta che mi capita dopo innumerevoli acquisti....comunque veniamo al sodo...come suona..io direi molto bene...per quello che costa molto piu' definito del dac del philips attualmente e collegato alla coassiale del lettore un po di rodaggio lo deve fare ma le prime impressioni sono buone...diciamo che non avendo mai preso un dac questo è un buon inizio , il suono e cristallino e scintillante credo che dopo un po di ore dovrebbe mitigarsi..ma questo è da vedere...piu' tardi lo collego all'usb del computer e vediamo che mi dice foobar...
macmax- Affezionato
- Data d'iscrizione : 22.06.12
Numero di messaggi : 193
Impianto : s.m.s.l sa-s2 2021b casse ar spirit 122 con woofer ciare..sintoampli denon avr 1800...lettore cd philps cd 104 piatto kenwood kp 3022.
Tienici aggiornatimacmax ha scritto:Dunque ho preso il dac in questione e sta suonando da un paio di ore sul mio impianto attualmente composto da maccanica philips cd 930 fenice 20 e diffusori monovia con monacor sp 155 x...in tqwt...preso da singapore e arrivato in 15 giorni..oggi me lo porta la postina con 11 euro di dazi..vabbe' e la prima volta che mi capita dopo innumerevoli acquisti....comunque veniamo al sodo...come suona..io direi molto bene...per quello che costa molto piu' definito del dac del philips attualmente e collegato alla coassiale del lettore un po di rodaggio lo deve fare ma le prime impressioni sono buone...diciamo che non avendo mai preso un dac questo è un buon inizio , il suono e cristallino e scintillante credo che dopo un po di ore dovrebbe mitigarsi..ma questo è da vedere...piu' tardi lo collego all'usb del computer e vediamo che mi dice foobar...
dunque collegato in usb il computer me lo riconosce come c-media usb headphone...settato in output di foobar e funziona alla grande!!! ora marcus miller suona davvero....sicuramente non è a livello degli altri piu' blasonati ma quello che costa li vale tutti....e tutto il pomeriggio che suona e già e piu' smussato come suono...comunque di una cosa ho avuto la certezza sul pacco che mi è arrivato ci stava il valore dichiarato..e infatti lo sdoganamento e stato molto piu' veloce ed il pacco non è stato nemmeno aperto...aveva dichiarato 35 dollari..questo sostiene la tesi di molti che dichiarare il valore e vero che ti espone a dazi ma le cose arrivano piu' in fretta si facilità il lavoro alla dogana.
macmax- Affezionato
» Come vi sembra questo DAC?
» Come vi sembra questo USB DAC?
» come vi sembra questo kit?
» nuovo class-T Muse? (TK2050)
» Sembra interessante....
Oggi alle 17:38 Da RUR
Oggi alle 16:55 Da Aquileia1969
Oggi alle 12:48 Da Quaiozi!
Ieri alle 20:11 Da salvo93
Ieri alle 18:15 Da fileo
Ieri alle 17:06 Da skyufo
Ieri alle 11:35 Da Gedeone
» Pioneer PD 4100
» DAC su Raspberry e Volumio
» Consiglio per DAC
» Strani segni sul vinile
