Impressioni di ascolto di line array?
A nessuno è mai capitato di ascoltare in qualche negozio o fiera i line array della McIntosh o di altri produttori?
Questi sono i McIntosh:
http://www.mcintoshlabs.com/us/Products/pages/ProductDetails.aspx?CatId=Speakers&ProductId=XRT2K
http://www.mcintoshlabs.com/us/Products/pages/ProductDetails.aspx?CatId=Speakers&ProductId=XRT1K
Da un po' l'idea dei line-array per ascolto hi-fi home mi sfruculia e sto pensando di costruirne un paio, mi piacerebbe però, prima di imbarcarmi nell'avventura, avere qualche impressione di ascolto di prima mano
Switters- Membro classe oro
Numero di messaggi : 5072
Re: Impressioni di ascolto di line array?
Ho sentio parlar bene di questi:
Gli Audience.
Vendono anche il singolo Ap:
L'Audience A3
Questo è il litraggio suggerito per un box da 2 AP:
http://www.audience-av.com/parts/applications.php
Gli Audience.
L'Audience A3
A basic design for a 2 driver speaker would be to install 2 A3’s in a 5L sealed box. Wall mounting will eliminate the baffle step and enhance bass response. Outside dimensions of a 5 L box can be 12” high x 6.5” deep X 7.5” wide, using ¾” material. We recommended that the box be well sealed as these drivers are capable of generating real bass power. No bracing is required when using ¾” enclosure material. A full handful of loose wool is recommended for cabinet damping, adjust to your taste. The A3 drivers should be flush mounted and the cutouts need to be very generously beveled inside away from the driver to un-shroud the back side of the cones.
For in room positioning, ports can be used to increase the bass output, however, with some tradeoffs. At frequencies below the port tuning the driver becomes unloaded allowing free motion. This can lead to over excursion and driver damage if played to loud. One way to avoid this is to tune the port to 45Hz or less leaving little program material below this frequency to cause a problem. With a 6L volume per driver, 45Hz tuning will give 40Hz at -3db. A good solution is to use 4 or more drivers in a proportionately larger enclosure to handle the low frequency power.
bru.b- Membro classe bronzo
Numero di messaggi : 1390
Provincia : Torino (Ivrea)
Streamer - Rasp 3 + Digione
Aune S6 Pro
Mannaggia a me e quando porgo la mela di Eva
Secondo me hai tutto per fartene due di ottimi Array ti mancano solo i Woofer e i Tweeter
Tweeter senza dubbio Ribbon e per il woofer senza svenarsi prenditi i Dayton Audio DC 300
Potrebbe essere un buon progetto da portare avanti con gli amici del T-Forum parliamone
wasky ha scritto:Mannaggia a me e quando porgo la mela di Eva
Ma veramente è qualche mese che ci sto pensando:
https://www.tforumhifi.com/t16751-line-array-ci-facciamo-un-pensierino
Solo che sono un po' lento, ma adesso che ho il microfono di misura, tsk... devo solo imparare a usarlo...
Come avevo già scritto nel post linkato sopra, se qualcuno è interessato al progetto si puà vedere di formare un gruppo di lavoro...
Switters ha scritto:Ma veramente è qualche mese che ci sto pensando:
Ora vado a vedere
Per me Ok puoi contarmi nel gruppo anche come finanziamento lavori
Hai poi spulciato lo shop che ti ho linkato ? Andando sul pro si spende poco e si acciuffa bene
wasky ha scritto:Switters ha scritto:Ma veramente è qualche mese che ci sto pensando:
Ora vado a vedere
Ho spulciato, ho spulciato... Ma mi è venuta anche un'idea, magari nei prossimi giorni mi dici quando sei comodo che ci facciamo una chiacchierata.
» Line Array, ci facciamo un pensierino?
» Line array, impedenze sensibilità e potenze
» Progettare casse mini-line-array (P.A.).... help ...
» V-DAC II
» Energy RC-30 sono un affare?
» V-DAC II
Oggi alle 16:55 Da Aquileia1969
Oggi alle 16:33 Da RUR
Oggi alle 12:48 Da Quaiozi!
Ieri alle 20:11 Da salvo93
Ieri alle 18:15 Da fileo
Ieri alle 17:06 Da skyufo
Ieri alle 11:35 Da Gedeone
» Pioneer PD 4100
» DAC su Raspberry e Volumio
» Consiglio per DAC
» Strani segni sul vinile
