Un 4*100w basato su TC2000 e TP2050, che ne pensate?
Ciao a tutti... sono in procinto di comprare un'ampli per il mio sistema (alle 2 casse ho aggiunto un sub, la vernice sta ancora asciugando ). Che ne pensate di questo?
Dite che ha una qualità decente? (non chiedo la qualità della Fenice 20, ma almeno quella del T-Amp originale... da considerare che il 90% del tempo lo terrei sui 10w rms...).
Che ne pensate?
PS: siamo sui 50$, una volta aggiunto alimentatore e spedizione dovrei stare sui 100€...
Brief Introduction:
Based on two TC2000 and four TP2050 chips from Tripath, this class-D audio amplifier board allows the creation of really good sounding multi-channel systems. Being compatible with power supplies ranging from 10V-30V, it can be used in many audio systems. This amplifier has four channels, all with the same power up to 100W each and sound quality, so the sound quality is simply outstanding. You can use any number of channels you like, and leave the others unused.
This is an exceptionally well designed amplifier, with a lot of power reserve, high fidelity, low distortion, good S/N ratio, high sensitivity, low consumption and full protection. Having all these almost ideal characteristics this amplifier is likely to become the basic building block of your future high fidelity system, or it can also become the element that will upgrade your existing system.
Features:
* Several wiring methods facilitate connection.
* Mounting holes are available for easy installation and fix.
* Excellent heat sink eliminates your worry over heat dissipation.
* "Audiophile quality" sound
* A perfect "Class D" architecture
* Operating voltage range: 10V-30V, the maximum voltage of power supply is 32V
* Frequency response: 20Hz-20KHz (±3dB)
* Signal/Noise Ratio:100dB
* High Output Power
* 30W @ 6Ω, < 1% THD+N
* 40W @ 8Ω, < 3% THD+N
* 100W @ 4Ω, < 10.0% THD+N
* High Efficiency
* 86% @ 60W 8Ω
* 82% @ 46W 6Ω
* 90% @ 100W 4Ω
* Audiophile Quality Sound
* 0.007% THD+N @ 30W 8Ω
* 0.005% THD+N @ 70W 4Ω
* Line level analogue audio input
* Over/under voltage turn off
* Over current protection
* Over temperature protection
* Over 90% components are SMT based, which are reliable and environment-friendly
* Ideal for DIY and industrial applications
Che ne pensate?
Re: Un 4*100w basato su TC2000 e TP2050, che ne pensate?
Il solito della sure ...
http://cgi.ebay.it/4-100W-TK2050-TP2050-Tripath-D-class-Amplifier-Board-/350384826287?pt=LH_DefaultDomain_0
Non mi ispira ... sembra mal realizzato.
Barone Rosso- Moderatore
Ecco, come immaginavo... in effetti il prezzo era troppo basso...
Grazie!
Grazie!
penguin86 ha scritto:Ecco, come immaginavo... in effetti il prezzo era troppo basso...
Grazie!
La tk2050 a due canali è realizzata meglio. Ma deve per forza essere modificata.
Fa un pensierino a questa:
http://www.diyaudio.com/forums/class-d/164274-new-tk2050-board.html
Sembra interessante, ma non riesco a capire dove si trova (a parte taobao.com)...
E' reperibile in Italia? Che potenza ha?
Scusate, ma sono un po' niubbo
penguin86 ha scritto:Sembra interessante, ma non riesco a capire dove si trova (a parte taobao.com)...
Solo dalla Cina.
Neppure quella che hai citato nel topic è reperibile in Italia.
2x100w (circa)
http://hifimediy.com/Home.html
No China -> No Party
madqwerty- Moderatore
Grazie per il link del negozio, è quello che volevo
Speriamo non me lo blocchino in dogana...
Grazie dell'aiuto, ragazzi
» HelderHifi - MKII TC2000+STA508 Tripath &ST 100W
» [VENDUTO] Sure TK2050 100W+100W 45€ +ss
» Trends Audio TA-10.1 vs Winsome Mouse ovvero TA2024 vs TP2050
» scheda basata sul tc2000 300w su 4Ohm
» 100W con 1.5V!
» 100W con 1.5V!
Oggi alle 13:23 Da Quaiozi!
Oggi alle 13:01 Da salvo93
» WHARFEDALE Aura 2
Oggi alle 9:55 Da giucam61
Oggi alle 4:52 Da Gionni
Oggi alle 0:07 Da arthur dent
Ieri alle 23:19 Da bertuc79
Ieri alle 21:08 Da lello64
Ieri alle 17:25 Da lello64
» SACD e ascolto dsd nativo
